Tom Senior vertical milling head
Home Forums Manual machine tools Tom Senior vertical milling head
Viewing 2 posts - 1 through 2 (of 2 total)
  • #257691
    Jeremy Glenn
      @jeremyglenn18958
      Please can anyone tell me if there is a difference in size between the vertical milling head fitted to the Tom Senior M1 and the Junior mill? The circular mounting boss, marked with degree graduations on the Junior I am looking at is 130mm in diameter and has two loose mounting bolts still attached and I am keen to know if the M1 head will fit it or if the head is a much smaller version with a different drive arrangement.
      Thanks,
      Jeremy.
      #12773
      Jeremy Glenn
        @jeremyglenn18958
