I think I’m in love… with a metal bender :-)
Home Forums Manual machine tools I think I’m in love… with a metal bender :-)
  • #12652
    Bikepete
      @bikepete
      #230489
      Bikepete
        @bikepete
        Watch this and tell me you don't want one:
        A whole lot of versatility and (in contrast to most sheet metal machines) it takes up very little space – it could live on the front of a work bench semi-permanently without getting in the way…
        And even better, the inventor has posted a superb, clear write-up for anyone wanting to build their own! Click here. All looks do-able, and the electronics aren't too complicated either…
        Think it's just stolen top spot on the projects 'to do' list…
        #230496
        Ian P
          @ianp
          Two hours have elapsed, more than 250 people have looked at this posting and I'm surprised there are no comment yet.
          I think its very impressive and within its capabilities is very useful tool. As my grandaughter would say the hinges are 'awesome'!.
          What a breath of fresh air it is to see a designer selling a commercial product and freely giving so much design information away.
          Yes I want one.
          Ian P
          #230498
            Clever stuff yes
            And … being one that likes patent information:
            john swift 1
              @johnswift1
              I watched the video a while ago after a post here or possibly madmodder . net
              I'm not a sheet metal worker but the magnabend bender looks like it will be a usefull
              alternative for DIY metalworkers here
              Spurry
                @spurry
                Very neat tool. I wonder how much it costs….?
                Pete
                #230507
                Steven Vine
                  @stevenvine79904
                  Posted by Spurry on 17/03/2016 23:09:18:
                  Pete
                  The 650e was quoted at $3850AUD, about £2033. Gulp.
                  Steve
                  #230508
                  Clive Foster
                    @clivefoster55965
                    The hinges are indeed awesome and will take some careful engineering to replicate. Hafta be a lot better at 3D visualisation than I to figure exactly how to get the right pivot and rotation on the upper joint. Basic prinicples are pretty clear but calculating the detail dimensions to make it work is a whole nother thing.
                    The bend angle stop system on the handles is excellent too. Good example of lateral thinking and much better than the usual protractor thingy.
                    Clive.
                    #230510
                    Bill Pudney
                      @billpudney37759
                      Very clever, extremely well thought out. Although it's not cheap the price isn't outrageous, when the price of a conventional folder is considered.
                      Well done Mr Magna-Bend, the best of luck!!
                      cheers
                      Bill
                      #230513
                        JA
                          @ja
                          Very impressive and I also want one …….. If only I had a nice clean workshop.
                          I fear that all the steel debris, lost small nuts and bolts etc in my workshop would migrate to the residual magnetism of the clamp and hinder its use. When in use I guess the clamping strip would act like a keeper and the strong magnetic field from the electromagnet would not be a problem. However, I would think the steel core of the magnet would retain some magnetism after use, but I may be wrong. Even so a demagnetizing system could be easily built in.
                          Sorry, I feel I have been a wet blanket.
                          JA
                          #230527
                          Bikepete
                            @bikepete
                            JA, re residual magnetism – that's addressed by the inventor at some length here. Seems the circuit delivers a 'reverse pulse' to get rid of it…
                            #230544
                            JA
                              @ja
                              Posted by Bikepete on 18/03/2016 09:18:51:
                              Thanks. I read the main article before going to bed and wrote the above on getting up.
                              JA
                              #230549
                              MW
                                @mw27036
                                I quite like how neatly it can bend to offset angles.
                                The angle scale is a must.
                                Michael W
                                Edited By Michael Walters on 18/03/2016 11:08:25
                                #230562
                                frank brown
                                  @frankbrown22225
                                  I can't see how you would bend up a tray. You need fingers to go inside the first two bent sides.. Selection of shorter clamps?
                                  Frank
                                  #230581
                                  Gray62
                                    @gray62
                                    Posted by frank brown on 18/03/2016 11:55:52:
                                    Frank
                                    If you watch the video, at about 4 mins in you will see their solution to this.
                                    #554856
                                    Philip Trueman
                                      @philiptrueman
                                      I have a Magnabend 1250E I bought it about 10 years ago and use it a lot. I manufacture traliers for gliders and i use it for all the small bends. I have even used it to fold the long edge of a 2500mm sheet but i had to re position it 5 times to get a 90 degree bend. It bends up to 1.6mm galvanised steel and short pieces of 3mm mild steel. I nearly bought a 3200 model on e bay but i ended up buying a plain 2500mm sheet metal bender which weighs nearly 1 ton.
                                      There is not a lot that you cannot bend with the magnabend. It is very accurate at folding. I had a few problems with a couple of the resisters but the release mechanism problem is solved now.
                                      #554878
                                        There is a later type of bed design for these benders. Fabricated and possibly (very) slightly reduced magnetic field.
                                        Also a fresh design for the hinges, making them easily constructed by any competent hobbyist.
                                        I’ve got a pile of bits suitable for making one – but not the copper – and intended starting earlier than now. I might make a start by the end of the year, but that will be dependent on increasing my workshop area, which is not looking good!
                                        #554881
                                        Philip Trueman
                                          @philiptrueman
                                          https://www.youtube.com/watch?v=1LFNo6zW-Iw
                                          Here is a link to an engineer who is making some magnetic benders just like the magnabend.
                                          Edited By Philip Trueman on 20/07/2021 07:40:07
                                          #554882
                                          Gray62
                                            @gray62
                                            Posted by not done it yet on 20/07/2021 07:22:25:
                                            Do you have a link for the hinges and the later bed design please?
                                            Gray
                                            #554892
                                              Googling “Magnabend handyman” will throw up several facets of the easier build.
                                              #554942
                                              duncan webster 1
                                                @duncanwebster1
                                                Posted by Bikepete on 17/03/2016 20:37:11:
                                                Watch this and tell me you don't want one:………
                                                OK, I don't want one. Haven't got space
                                                #555212
                                                Keith Hale
                                                  @keithhale68713
                                                  Is that all it does?
                                                  My wife has got one made in the mid+40's and she reckons that her's is far more versatile. It cuts grass, trims hedges, makes tea, and carries shopping. The list is endless!
                                                  Like Duncan, haven't got space for another one!
                                                  #555219
                                                  BOB BLACKSHAW 1
                                                    @bobblackshaw1
                                                    Not much use if you suffer with back problems, impressed with the deep channel that can be bent as a swan neck tool has its limitations.
                                                    Bob
