Pillar drill spindle return spring.
Home › Forums › Manual machine tools › Pillar drill spindle return spring.
  • #215792
    Gary Magowan
      @garymagowan
      I have a Rexon RDM 80B drilling m/c which needs investigation. The spindle has got some play and has started to make unhealthy sounds when starting a hole. i would like to strip the spindle down to check bearings but having had previous experience of tussling with tensator springs, in other equipment , I am reluctant to start the stripdown without some inside info.
      Can anyone help?
      #12590
      Gary Magowan
        @garymagowan
        Are these difficult to remove and replace?
        #217519
        satya prakash
          @satyaprakash91654
          How much time your Rexon RDM 80B drilling is old. if bearing problem use standard heavy duty bearing in your machine.
          #217614
          john carruthers
            @johncarruthers46255
            Have you watched this guide?
            https://www.youtube.com/watch?v=gWwmgC_TkBQ
            #217669
              They are easy to get off and back on, but it's also very easy to tear a chunk out of your finger in the process. One solution is to wear gloves and tie a piece of wire around the hooked end of the spring. Then pull the hooked end out of its slot and slowly let off the tension while keeping hold of the wire.
              #217702
              Gary Magowan
                @garymagowan
                Thanks, John for the link. That put my mind at ease. So I'll gird my loins and get on with it as soon as I can do without the drill for a few days.
                Thanks again.
                Gary
