Posted by Hopper on 25/07/2020 01:50:32:
I'm not sure about their claim the builder invented the dreadnought style wheels — sure I've seen them on old steam traction engine pictures. But he seems to have patented the idea for Australia at least.
The original version of this style of wheel was designed and developed by James Boydell around 1850 and further developed in conjunction with Charles Burrell and Sons.
The primary difference between the Boydell "walking wheel" design and the Bottrill "dreadnaught" version is that Boydell used one row of flat board plates and Bottrill two overlapping rows of slighlty curved ones. Obviously some sort of overlap is needed if the device is to work as things will clearly just jam up as the wheel moves off the first board when the flat end of the next one spiles onto the surface.
For his "walking wheel" Boydell used a series of steps on the board ends, 3 or 4, to generate enough overlap to prevent jamming.
Bottrill used two rows of boards with considerable overlap.
Pedrail systems used many short pads arranged and sized so that at least two were always in contact with the ground so jamming could not occur. This required a mechanism to tilt the pads to the correct angles as they came into contact with the ground and move with the wheel as it rotated. This mechanism was heavily loaded, often over-complex and never really sorted out to any satisfactory level of reliability.
Due to the large size of the boards Boydell was able to use a simple pivot and offset link, assisted by gravity, to provide the necessary tilt on his walking wheel. With only 6 boards the ride was inevitably somewhat rough. The overlapping boards on the Bottrill version effectively doubled the number of flats giving a smoother ride but needed a more complex linkage to generate the correct angle between successive boards. Coming up with something sufficiently simple, strong and robust enough to survive in rough country is not as easy as it seems at first sight.
Edited By Clive Foster on 25/07/2020 10:29:15
Edited By Clive Foster on 25/07/2020 10:29:42
