If anyone is interested, my thermostat is set at about 18 C.
Being well insulated, the 2 Kw fan heater heater, once the shop is up to temperature, cuts in infrequently. aided by by heat from machinery and myself.
Any combustion heater needs to have the products of combustion vented outside (And the system to be well sealed, to avoid you being poisoned by carbon monoxide, let alone any water vapour escaping into the working area
By all means insulate, but do not seal completely. Leave the bottom of the door unsealed so that the moisture from the wet bikes can escape.
Years ago, I sealed the bottom of the garage door, and the car rusted like crazy!.
Also, you need some fresh air to breathe!.
My small shop has two small fixed vents at floor level, and a fan, at high level, that can be switched on when needed, exhausting into an external weatherproof hood.
