Wilding’s Small Tower Clock
Home › Forums › Clocks and Scientific Instruments › Wilding’s Small Tower Clock
  • #457451
    gerry madden
      @gerrymadden53711
      Hi Clockmakers,
      I have embarked on the above to keep me busy while the world goes into lockdown. Right now I'm drawing it all up so I can see properly how it all fits together. I plan to make a few "upgrades" (time will be the judge of that!) but there's also a few things that I don't quite understand. For example:-
      1) On the pallet arbor there is no bearing bush on the pendulum end. The shaft runs directly in the apron. If it's because there is little load on this shaft, he could have done this at the other end but he didnt. What am I missing ? (I think I might try PTFE here anyway.)…..ahhhh as I write its just occurred to me that this might be his way of being able to adjust the end-float for the shaft.
      2) The crutch assembly comprises of a fulcrum block and an arm. There are beat adjusting screws on the arm which move the fulcrum block. Then on the fulcrum block there are adjustable crutch pins to take out the play. My simplistic thinking is that the two parts (arm and fulcrum) could be one, with the beat adjusting screws made to do both beat and rod clearance adjustments. Again, what might I be not seeing ?
      3) Instead of wood, I thought I might use good old Tufnol for the barrel. Any negatives, apart from cost ?
      Gerry
      #3874
      gerry madden
        @gerrymadden53711
        #457456
          Forgive me asking, Gerry …
          Would that be Wilding's small Tower Clock ?
          David Noble
            @davidnoble71990
            Hello Gerry,
            This clock really tempted me before I settled on the one I'm making at the moment. So I will be following your progress with interest.
            David
            #457476
            lfoggy
              @lfoggy
              John Wildings tower clock is on my 'to do' list as well. Can't answer your questions but good luck with the build.
              #457493
              gerry madden
                @gerrymadden53711
                Ahhh yes Michael. I was wondering how long it would take for the deliberate error to be spotted ! I think I must have been mixing things with 'John Wild', the clock man in Sheffield. …Damn corona.. playing havoc with the brain cells…
                #457494
                gerry madden
                  @gerrymadden53711
                  Can the moderators correct the title so as we don't confuse people for the next ten thousand years ?
