Why mostly manual cars in UK
Home Forums General Questions Why mostly manual cars in UK
Viewing 11 posts - 76 through 86 (of 86 total)
  • #440663
    Vic
      @vic
      “Sealed for life”, “Parts not available”, “£100 a litre for oil” … All sound like good reasons to choose a manual unless you buy a new car every few years.
      Samsaranda
        @samsaranda
        I drive a Honda Jazz with auto gearbox, it’s a dream to drive and with the paddles I can select any gear that seems necessary. The comments in this thread have made me think back to my time in the services when I used to have to drive ancient Bedford de-icer tankers that had awful gearboxes and the steering wheel was about the size of a railway turntable, no power steering in those days just huge biceps.
        Dave W
        #440686
        Dave Halford
          @davehalford22513
          Posted by Vic on 07/12/2019 10:03:29:
          There’s not a lot to go wrong in a manual gearbox. I’d hate to see the repair bill for a modern auto box though.
          Just wait till the dual mass flywheel quits on your manual box, that'll make your eyes water smiley
          #440691
          Dave Smith 14
            @davesmith14
            I have driven a lot of automatics, but why do I still prefer a manual? As with everything its personal preference, I LIKE changing gear and it also allows me to have the car in the part of the power band I want it in not what the car thinks its wants to be in.
            #440696
            RMA
              @rma
              Posted by Vic on 07/12/2019 16:21:14:
              All main dealer hype I'm afraid and simply not true. With most auto boxes you can drop the sump, change the filter and refill with fresh fluid quite easily. Main dealers don't seem to employ engineers anymore, even service reception at my main dealership is 'manned' by young girls who haven't a clue about cars. They always say leave the car for a day even for the simplest thing. It's all geared up to selling complete units and preferably a new car!
              #440703
              Vic
                @vic
                Posted by Dave Halford on 07/12/2019 19:09:45:
                My car doesn’t have a dual mass flywheel.
                #440705
                vintage engineer
                  @vintageengineer
                  The only reason modern cars have dual mass flywheels is they can cut costs by using weaker crankshafts and gearboxes. It's cheaper to make a dual mass flywheel than stronger cranks and gearboxes.
                  If you fit a solid flywheel to most modern cars you will snap the crank!
                  #440714
                  Mark Gould 1
                    @markgould1
                    Posted by Dave Smith 14 on 07/12/2019 19:41:01:
                    a lot of modern cars these days Allow you to choose between automatic and manual. I have a Audi with an S-Tronic box which I can leave in “D” or change to “M” which allows me to use the paddles to change gears. Best of both worlds I suppose.
                    #440727
                    Vic
                      @vic
                      Posted by vintage engineer on 07/12/2019 21:54:52:
                      I repeat, my car doesn’t have a dual mass flywheel and it’s not yet three years old.
                      #440731
                      vintage engineer
                        @vintageengineer
                        Any clues to what you drive?
                        Posted by Vic on 08/12/2019 10:06:44:
                        #440736
                        Tim Stevens
                          @timstevens64731
                          To return to the original question (but why change the habits … etc) –
                          Before WW2, most cars had gearboxes that required experience and skill to operate. So, most drivers avoided changing gear, and looked for cars which did not require such skills. Meeting the demand, makers used low compression engines with unexciting valve timing and big flywheels, and these cars were capable of about 5 – 50 mph in top gear. At the time the UK speed limit was 20 mph, so there was no incentive for much progress. As a result, the enthusiast (who had, or tried to have, the needed skills) relied on a specialist market place os what we would now call sports models, if he could afford it.
                          In the 1930s, fluid flywheels, and then synchromesh, were developed and much of the problem went away. At the same time, the removal of the 20 mph limit and the wider spread of tarmac in the countryside encouraged the use of valve overlap (shock horror), and lots of smaller-car firms turned out 'sports cars' – Wolseley, MG, Singer, Frazer-Nash, Riley, Alfa-Romeo, etc. The divide between 'ordinary motors' with saloon (sedan) bodies, and old-fashioned performance, and 'sports cars' with touring (open) bodies continued the idea that 'proper motoring' required skill, and anything that took away the need for skill was regarded as only for women and old men – and this included easy-changing systems. And such notions tend to stick – you only have to look at Top Gear to be reminded of this.
                          In other countries away from the UK with its restrictions and aged traditions different rules applied, of course.
                          I hope this bit of background is helpful.
                          Cheers, Tim
