Well folks, I don’t know anything at all about oils, but reading what has been written above does all make sense to me, especially as I’ve known since my Beetle owning days about detergent oils. Which suggested to me that I really should change.
I’d already found about the headstock grease from Castrol many years ago, but perhaps rather naively thought that motor oil would do elsewhere, but when I found I could buy small quantities from Hallets I decided that hang the cost, I’ll do it. It does mean though that even though I’ve just done a major clean and relube with motor oil, I perhaps should consider doing it again but with the correct stuff this time.
One thing I won’t be changing is my use of Rocal Slideway spray lubricant for the cross-slide and the top-slide, reason being that I’ve got the stuff and it certainly makes them better. I won’t be doing it for the saddle/bed slideway because I keep cleaning the bed etc, and hence wiping anything off, but in anycase, there is an oil hole which allows oil to get onto the bed underneath the saddle from whence it appears to be spread around by the plastic wipers at each edge of the saddle. Therefore it’s easy to reapply an oil for the bed/saddle, but there is no such device for the other slides, hence the Rocol stuff should last considerably longer.
I should point out that in my case I do not have any oil bath places – it all relies on a drop here, a drop there, a drop elsewhere etc – a sort of total loss system which in turn does suggest that Martin (Blowlamp) may well have a good point in my case.
Anyway, I’ve done it now, so I’ll have to stick (a-hem) with it. And the old motor oil will be used for the garden shears etc, anything else which just needs a covering of protective oil – bars of bright steel for example, and on hacksaw blades and drill bits when cutting through steel – anything not too important and for which total loss is irrelevant.
Peter G. Shaw
