Which Lathe???
Which Lathe???
Home Forums General Questions Which Lathe???
Viewing 25 posts - 51 through 75 (of 78 total)
  • #462792
    Paul Smith 37
      @paulsmith37
      NO dont get political or harp on about waste of resources. Please. I came here to escape that.
      Paul Smith 37
        @paulsmith37
        Posted by Andrew Evans on 06/04/2020 15:33:43:
        **LINK** – what about something like that
        Physically that seems to tick most of the boxes…Thanks Andrew. MT3 too. quite why that wasnt fitted to the super 7 i dont know?
        #462798
          Posted by Paul Smith 37 on 06/04/2020 14:43:51:
          One thing ididnt like about the warco was the three nuts to hold the chuck on, screw on chucks are far easier.
          Yeah, but no, but maybe! Broken teeth are a common problem on Myfords. It's because screw-on chucks tend to jamb over time and unwise attempts to get them off is likely to break something. Another major disadvantage is they come undone when the lathe is run in reverse. Though screw-on chucks give good service, I feel a fixing method with two faults can't be ideal.
          Bolt on chucks cure both shortcomings. And being able to run a lathe safely in reverse is useful. There's no risk, for example, of crashing into the chuck when screw-thread cutting in reverse away from the headstock. I do all mine that way at high-speed.
          Screw-on and bolt-on chucks are both inexpensive compromises rather than the best available. Camlock chucks can be reversed, don't jamb, and are super-quick to change. Shame about the price!
          A good reason to be wary of bolt-ons is lack of room behind the chuck. People with big fingers hate them!
          Ex contributor
            @mgnbuk
            Super 7s have a spindle lock that enages at the rear of the spindle pulley to avoid this ? Seems to be more of an issue on earlier Boxfords that didn't have a spindle lock.
            A "half way house" solution that offers the security of bolt-on,and almost as easy a change as a cam-lock (but without the expense) is the keyhole plate type – slacken the clamping nuts, then rotate the keyhole plate to release the chuck.
            Nigel B
            Edited By mgnbuk on 06/04/2020 16:58:40
            #462804
            Paul Smith 37
              @paulsmith37
              Its funny when you discuss all these problems that people seem to find solutions to the problem, and show a shortcoming of a particular principle. Good chat this
              #462806
              Mick B1
                @mickb1
                Posted by mgnbuk on 06/04/2020 16:58:14:
                Nigel B
                What's the make that used a big screwed collar onto a short tapered register, with a C-spanner? I remember liking those when I was doing it for pay, but can't remember whose they were – Wyvern? Elliot? Boxford? I think maybe Colchester used it too?
                #462823
                Ex contributor
                  @mgnbuk
                  L00 ? Used on the Boxford VSL & some Harrisons (the 140 at my last employment had this type, but may have been the bigger L01).
                  Nigel B.
                  #462828
                  Mick B1
                    @mickb1
                    I have to admit to reluctance to switch chucks on my Warco. It's not so much the 3 fiddly nuts (and they are) but that I'm worried about losing the superb concentricity (best = appx. 0.0006" ) of the as-issued 3-jaw if I should get some tiny speck of anything trapped in the register.
                    Edited By Mick B1 on 06/04/2020 19:52:17
                    #462840
                    Paul Smith 37
                      @paulsmith37
                      Posted by Paul Smith 37 on 06/04/2020 16:41:57:
                      well i checked out this boxford, (link above) but cant see that it includes fixed or travelling steadies.. so i found these.
                      Linky And i thought steadies for the ML10 were expensive…Jeeees.
                      #462848
                      Howard Lewis
                        @howardlewis46836
                        For those having problems holding the M6 nuts on mini lathes, DannyM2Z wrote a short article in MEW on making a widget to hold the nuts while they are removed or fitted. It is just a strip of thin steel, with two slits with tin snios, and a little bending.. Easy to scale up for larger nuts.
                        I made one and it works, so more searching for nuts dropped behind the chuck and into the swarf!
                        #462849
                          Posted by Paul Smith 37 on 06/04/2020 20:11:36:
                          so i found these.
                          Someone obviously has a sense of humour surprise
                          They’e just nasty square-edged ‘functional’ things … not elegant and curvaceous.
                          angel MichaelG.
                          #462850
                          Paul Smith 37
                            @paulsmith37
                            I thought that too.
                            #462938
                            thaiguzzi
                              @thaiguzzi
                              If you are happy to spend 3k i'd be looking at nice, fully tooled Colchester Students, Bantams, Harrison L series or M 250/300 series.
                              The above are not much bigger a footprint than a Myford and are 10 times the lathe, nay scrub that, 50 times the lathe.
                              If you put in the search function on Ebay or an ad on Tony's Lathes site, a nice fully tooled A series Boxford can be had for 1500 quid.
                              They are out there, you've just got to find them.
                              I'd want my head examining paying 3k for a Super 7, when a generic Chinese 12/24 – 12/36 can be had fully tooled for a grand less.Most of these 6" CH Chinese lathes are copies of the Harrison M series. Camlock spindles, induction hardened beds etc etc etc.
                              #462949
                              Howard Lewis
                                @howardlewis46836
                                Do allow cash for tooling, both for the machines, and for hand tools, Taps and Dies, Drill Chucks, Collet Chucks, Reamers, a bench grinder, a good bench vice, if these are not already in stock.
                                A cheap vice will be useless, possibly not accurate and will probably break at the least opportune moment. A steel vice will be expensive, but you will only need to buy it once.
                                You will,be surprised how much you finish up spending on tooling. But you don't have to buy it all at the same time.
                                Power supply and lighting for the shop and benches can take up capital, if not already in place.
                                #463040
                                Paul Smith 37
                                  @paulsmith37
                                  Thanks Mr Guzzi for the reply, i can see your point. but the bigger toolroom type lathes, do weight about 400 kilos+, so a diy move wouldnt be on the cards.
                                  Yes Howard, i thought that when i priced up the boxford sts10.20. the lathe itself isnt priced too bad ,but add another 770 pounds for a pair of steadies and whatever else you need and it wasnt such a bargain after all.
                                  Ive also found a Myford publication on what to check and how to check it on a potential new purchase, ive just checked my ML10 headstock and there is zero play in it. im pleased with that for sure.
                                  I made some T bolts today for the ML10 cross slide,and a wooden chuck plate for the bed, another win !
                                  #463048
                                  Ian Skeldon 2
                                    @ianskeldon2
                                    I don't think that link for the boxford steadies is accurate, you can get both fixed and moving for a LOT less than that. I agree with most of the comments already made, in so much as getting a ML7 wouldn't be any significant step up. Current Chinese stuff is hard to beat for the price but if you can find a decent used older lathe such as Harrison or Colchester complete with change gears and steadies etc then providing it has no real issues I would go down that route. You might be able to get a friend to help move/install it with you, choices, choices.
                                    #463049
                                    Paul Smith 37
                                      @paulsmith37
                                      Im trying to find out more about these boxford gear head lathes. Quite handy having three weeks off for annual leave
                                      #463050
                                      Tony Pratt 1
                                        @tonypratt1
                                        I fancied one of the 'newer' Boxfords but they seem to have a low top speed, I think the STS is only 1000 rpm?
                                        Tony
                                        #463056
                                        Paul Smith 37
                                          @paulsmith37
                                          The one i was looking at has a VFD fitted to it, so lord knows what speed it will run up to now.
                                          #463061
                                          Erik Werner Hansen
                                            @erikwernerhansen82920
                                            A 1000 RPM max. must be because it's a training lathe, built for education.
                                            A new motor, a VFD or a new pulley could change that easily. VFD is best – gives unlimited range.
                                            At that price, compared to the other lathes, I would do that. It looks like a good offer.
                                            I don't, because I have a Colchester Chipmaster "Continental" at 550 kg – too much for the OP.
                                            I have had a number of Super7's in great condition and left them because of:
                                            1. Only imperial leadscrew – if fitted with gearbox, then changewheels needed anyway, so why bother?
                                            2. No automatic stop or protection at all – if you make a mistake, it's costly.
                                            3. Threaded spindle nose – no quick braking or backlwards running.
                                            4. Size. Why pay a lot for a small, old design just because it's cult?
                                            I did that – and a Super7 is nice, but the only improvement since ca.1958 was power cross feed in 1974.
                                            I smile every time I touch my Chipmaster – it just feels so good. I fitted a Multifix toolholder – nice.
                                            And I kept the variator, even if Tony Griffiths falsely tells anyone to chuck the variator and use a VFD.
                                            The variator, although an old mechanical design, works wonderfully and is 3 times as good as a VFD!
                                            A Bantam is a cheaper version of the Chipmaster with gears instead of variator. Very common. Check for noise
                                            – gears wear, especially if abused in a school. But it should have the same feel as the Chippie. And it has a
                                            Camlock D1-3" spindle nose. Do yourself a favour and get Camlock (DIN55029) or Keyhole (DIN55027 (or 22))
                                            A Weiler LZ220 or Weiler Primus lathe would fit you sizewise as table lathes, but the first is rare and expensive
                                            and the other really costs a bloody fortune (I have had both).
                                            Cheers
                                            Erik
                                            Edited By Erik Werner Hansen on 07/04/2020 18:43:10
                                            #463091
                                            Paul Smith 37
                                              @paulsmith37
                                              Thanks Erik, theres a lot of food for thought there for sure. Ill continue my research !
                                              #463292
                                              thaiguzzi
                                                @thaiguzzi
                                                Re weight.
                                                You only move once. Or twice.
                                                Its not like you are moving on a weekly or monthly basis.
                                                Concur with the above, the Chipmaster is a wonderful lathe, and again not much bigger a footprint than a Super 7.
                                                #463316
                                                Erik Werner Hansen
                                                  A chipmaster is nearly 52 inches in length, but then you have to modify the hinges for the changewheel cover. I'll have to do that myself, since I don't have the room to fully open it.
                                                  But a Chipmaster with a working variator is becoming a rare item these days, I think. And it may be more lathe than the OP is asking for. I think it's a great lathe, but less might do?
                                                  Footprint is not all – I wanted a FP1 tool mill. Then I read the FP2 has only a slightly larger footprint. Forgotten was the much larger range of the X-axis, and in all it is much more beefy. So when every FP1 went to someone else (on eBay), I bid on a FP2 – and won. I now have one of each in my small 12 square meter workshop and I can attest, the FP2 takes up quite a bit more space. Half of it is intimidation, as the FP1 is smallish and rather cute, while the FP2 looks like it means business. 1100 kg vs. 660 kg is quite the increase.
                                                  So it is when comparing the Super7 with the Chipmaster.
                                                  But to the OP I'll say: Buy as much lathe as you have space for and can afford.
                                                  Cheers
                                                  Erik
                                                  Edited By Erik Werner Hansen on 08/04/2020 18:36:42
                                                  Edited By Erik Werner Hansen on 08/04/2020 18:37:04
                                                  Edited By Erik Werner Hansen on 08/04/2020 18:38:23
                                                  #463335
                                                  Paul Smith 37
                                                    @paulsmith37
                                                    TBH, Im not too worried about the money, as if you buy it right and look after it ,it will hold its money. 3k on a lathe doesnt frighten me,what is more important is buying a 3k lathe that needs 1k spent on it, with repairs and extra tooling, buying the lathe to find it wont do this or wont do that, and something that needs 6 men to shift it would be a pita.
                                                    Tonight ive just tried to see if i can in anyway spin a 6 inch round piece of aluminum of my Myford and make a big pullley, the answer i feel is no.I dont wish to make another buying error.The ML10 is a great machine but its a tad small for me.
                                                    #483480
                                                    ANDY CAWLEY
                                                      @andycawley24921
                                                      Anyone looking to buy a second hand industrial lathe(or even a brand new chinese offering) suitable for a home workshop could do a lot worse than look at the Leinen LZ4S that is currently advertised on homeworkshop.org situated in Halifax. I have no connection with the advert other than the fact that I own one also and think its a brilliant piece of kit. See what Tony has to say about them on lathes.co.uk.
                                                      If anybody on here buys it I would love to hear from them.
