What’s the best alternative to ‘loctited’
Home Forums General Questions What’s the best alternative to ‘loctited’
Viewing 25 posts - 76 through 100 (of 103 total)
  • #355075
      The box could end up containing more that the article particularly if it were something in readers tips.
      Brian G
        @briang
        Posted by Neil Wyatt on 23/05/2018 17:31:17:
        But what if it's an application where several types would do? What if the author uses what they have, rather than a cheaper or better alternative, simply because they happen to have it handy and it will do the job?
        That is why I believe the category of product as well as the product should be included, whether it is a sealant, retainer, adhesive, permanent or temporary threadlocker. "Bonded" tells us none of this, the last time I bonded anything it was with copper wire and a label saying "Safety electrical connection, do not remove" smiley
        As far as fits and tolerances are concerned, if we know the product used we can probably follow the manufacturer's instructions. After all, the clearance between silver soldered components isn't normally mentioned in articles.
        #355087
          Whoa hold on everybody! Think about what you are asking.
          Do you REALLY want me to contact every author who doesn't specify what adhesive they used?
          If I do that will the next request be for tolerances and fits to ISO specifications? Tooling used, including insert composition and code? Feeds and speeds? Exact alloy specifications for all raw materials? Material specifications for all fasteners? Colour codes for paint…
          Perhaps the next person who says they shined up a surface with emery should specify the actual abrasive, bond and grit size, or get their manuscript rejected.
          Very seriously, I suspect everyone who is asking for this data know exactly what they would use.
          An article to guide those who don't would be far more useful. Is anyone prepared to stick their head above the parapet and offer one?
          phil gardiner
            @philgardiner73127
            What was used before "loctite" ,maybe just a good fit.
            #355111
            Mark Rand
              @markrand96270
              I'm quite happy with the vernacular term 'loctited'. I'm far happier with an indication of which particular adhesive was used, and why. I quite often use Permabond 1046 for poor fits. Why? because I've got a couple of large bottles of the stuff and it's thicker than Loctite 603 or 648 smiley.
              Edited By Mark Rand on 24/05/2018 03:27:28
              #355115
                Posted by Neil Wyatt on 23/05/2018 21:11:51:
                Nobody wanted anything changed until YOU brought up the subjectdevil
                #355118
                not done it yet
                  @notdoneityet
                  Yep, best alternative is “loctited”!
                  If it ain’t broke, why try to fix it?
                  Edited By not done it yet on 24/05/2018 07:32:17
                  #355119
                    Posted by Mark Rand on 24/05/2018 03:26:31:
                    … I quite often use Permabond 1046 for poor fits. Why? because I've got a couple of large bottles of the stuff and it's thicker than Loctite 603 or 648 smiley.
                    Concise and helpful information, Mark yes
                    That's just the sort of note I would like to read in MEW articles.
                      Could lead to trouble though. I have a few old coat hangers and often use them as they are thicker than fuse wiresmile p
                      #355127
                      Samsaranda
                        @samsaranda
                        Jason, dangerous to joke about substitution for fuses, many years ago I remember a joke being made “ use a 2BA bolt “ and the dimwit tried to fit one in the fuse holder , stopped before any damage was done but a close shave.
                        Dave W
                        #355131
                          @mike89748
                          Back in the 1960s, when I was living in digs, my landlady complained she was getting shocks off her electric cooker. I went to the fuse box to pull the fuse, and found the cartridge had been replaced with a cut-down 6-inch nail. When I asked who had done such a stupid thing, she said it was her son, and he'd done it because six months previously the cooker kept blowing fuses. Another close shave…….
                          #355134
                          stefan ronde
                            @stefanronde37935
                            loctite 270 i prefer
                            #355138
                            not done it yet
                              @notdoneityet
                              And there was the bloke, in the US, who used a bullet as a fuse in his car. Not sure ig he completely joined the Darwin awards, but certainly would only have been firing on one cylinder, at best!
                              #355155
                              Speedy Builder5
                                @speedybuilder5
                                Will we have to be more precise about deburring to read such as "place 0.05mm radius on all edges and 45degree x 0.5mm chamfer on all holes. " or Like on the BBC, you will find Etc, Etc on page nn of the Radio Times, other listings are available. This is meant to be a Hobby Magazine, don't lets get too serious else Loctite will be just the start of a downward spiral.
                                BobH
                                #355181
                                  Posted by JasonB on 24/05/2018 07:04:53:
                                  I asked for a one-word alternative to the 'verb' 'loctited' not paragraph-long ones…
                                    Inspiration at last …. 'permabonded'.
                                    Sorted!
                                    not done it yet
                                      @notdoneityet
                                      Posted by Neil Wyatt on 24/05/2018 18:36:32:
                                      Sorted!
                                      Inspiration – maybe. Sorted – No.
                                      Still loctited for the vast majority, I would guess.smiley
                                      But if it ends this thread, all well and good.!
                                      #355189
                                        @mike89748
                                        A pal who is a retired toolroom engineer always calls these engineering adhesives/threadlockers "the bad engineer's friend." But then, he calls my copies of Model Engineer "Toytown Engineering", so maybe he isn't such a good pal after all…..
                                        #355191
                                          Yes lets get back to proper engineering terms and methods and have "light press fit" "firm press fit" and " shrink fit" for these the male part will have to be turned to  "full" nominal size to varying amounts and the female will have to be "shy" of nominal. At least the novice knew where he stood with these terms and could easily measure them with steel rule and firm leg callipers.crook
                                          J
                                          PS Neil is it's a sponsored article you will have to use "Truloced"
                                          Edited By JasonB on 24/05/2018 19:07:49
                                          #355193
                                          Roderick Jenkins
                                            @roderickjenkins93242
                                            Having used "loctited" on this very forum back in October I remain sceptical about "permabonded" entering the language.
                                            Anyway, I seem to be treading a lot of swarf about the house so I must go and electrolux the carpet. wink
                                            Rod
                                            #355197
                                              One very good thing about Permabond is the little book by Mr. W.A. Lees
                                              … It's a great pity that they have not seen fit to update it.
                                              I treasure my 1984 copy with its 'expert system' on floppy disk.
                                                Posted by JasonB on 24/05/2018 19:04:41:
                                                Good job you didn't use 'bare' instead of 'shy' face 3
                                                #355239
                                                I.M. OUTAHERE
                                                  @i-m-outahere
                                                  For a joke i covered the labels of my various loctite products with new labels of my own design :
                                                  Retaining compound became " stick ya bastard " , sealer became "don't leak ya bastard" and threadlocker became "stay there ya bastard " .
                                                  Any guesses what i call insect repellent ???
                                                  I used to work with a toolmaker that called retaining compounds snot and parts held together by it as snotted – his theory was that the person that made parts that needed snot on them could only work to tolerances that snot could run through ! I can sort of see his point as it really is like liquid sticky tape !
                                                  #355244
                                                  Clive India
                                                    @cliveindia
                                                    Posted by XD 351 on 25/05/2018 08:31:52:
                                                    For a joke i covered the labels of my various loctite products with new labels of my own design:
                                                    Good system. Like it.
                                                    Presumably demonstrates, despite numbers indicating otherwise, there are really only 3 types of Loctite.
                                                    I regularly us shitite as filler for keeping water out of electrical boxes. Muckite is the cheaper alternative.
                                                    Edited By Clive India on 25/05/2018 09:38:12
                                                    #355296
                                                    John Reese
                                                      @johnreese12848
                                                      Some brand names have been adopted as generic terms: Crescent wrench, Kleins (lineman's pliers), Stillson wrench, etc. I think the same is happening with Loctite.
