What makes your bristle?
Home Forums General Questions What makes your bristle?
Viewing 12 posts - 26 through 37 (of 37 total)
  • #404257
    Sam Stones
      @samstones42903
      Right again Neil,
      Stiffness = Softness sad
      I should have stuck with the deflection for a cantilever Δ = WL3/3EI
      Bill,
      Your photographs of the toothbrushes show they are different designs.
      As Hopper suggests, try swapping them over.
      Sam smile d
      Cornish Jack
        @cornishjack
        Hopper and Sam, thank you, Hopper, particukarly for waking up my dormant intelligence cells!!blush (especially for NOT pointing out that it was "bleeding obvious"!!) Of course that should be the first step and has now been done – results will require a week or so.
        Neil – only me, SWMBO has her own.
        Mark – constantly – but none have access to my bathrooms!!
        rgds
        Bill
        #404758
        Cornish Jack
          @cornishjack
          Well then chaps – for all those who have been waiting with 'bated breath and unable to contain their excitement at the possible revelations, we have an answer … it was the toothbrush what done it!!! Hopper pointed out the investigatory route and Sam correctly identified the cause and the culprit. The two brushes are, indeed, very slightly different in design and the culprit version allows minute quantities of 'slurry' to percolate through the body, down to the charger base, where it settles into 'yucky goo … that is a technical term, of course!. Soooo, problem identified but not cured. Thank you to all contributors – ME Forum is magic!!smileyyes
          rgds
          Bill
          #404819
          Sam Stones
            @samstones42903
            I'm pleased to know, Bill.
            How will you fix it, cos it seems like a design or manufacturing fault.
            I reckon Big Clive would be interested to pull it apart, see …  http://bigclive.com
            Sam smile d
            Edited By Sam Stones on 12/04/2019 22:49:29
            #408678
            Sam Stones
              @samstones42903
              Back again Bill.
              I thought you'd be interested in the (potential) consequences of water leaking into the inside of your cordless tooth brush.
              Matthias doesn't often 'DO' strip-downs.
              Sam
              #408680
              Grindstone Cowboy
                @grindstonecowboy
                Stripping down a Braun, rather than a Phillips, can be seen here.
                #408687
                Sam Stones
                  @samstones42903
                  A good one Rod. Not so brutal.
                  I noticed that I was holding my breath at several stages as his soldering iron touched where it shouldn't have.
                  With several thermoplastic mouldings, there was a potential for one or other to be polyacetal (POM).
                  The fumes from burning POM can lift your head off, so be careful chaps.
                  Sam
                  #408694
                  Mark Rand
                    @markrand96270
                    So should one use the cerium oxide or diamond paste polishes, or stick with Solvol Autosol,which comes in a handy tube?
                    #408826
                    Tim Stevens
                      @timstevens64731
                      If there is a problem with tooth goo running down inside the device, would it not make sense to brush your teeth while hanging upside down?
                      tim
                      #408872
                      Sam Stones
                        @samstones42903
                        It still happens down here Tim cheeky
                        #408874
                        Danny M2Z
                          @dannym2z
                          While we are discussing teeth, these tiny brushes are great for cleaning model engine spraybars and removing swarf from small tapped holes (especially blind holes) Interdental Brushes
                          Does this qualify for MEW 'Readers' Tips' Neil?
                          * Danny M *
                          ps. Why does 'swarf' get underlined with a red squiggle, surely it's a common word on this forum?
                          #408890
                          FMES
                            @fmes
                            I prefer to use an ultrasonic.
                            You do have to take a deep breath before putting your head in, upside is you can do your ears at the same time.
                            Mind you don't have it too hot tho'
