The first link shows a pure Lucas CF and no way did Lucas and Chloride help each other Neil, Lucas more or less ruined Chlorides automotive battery sales via various patents. They couldn't match the prices either.
Out of interest the step down was via a chain drive as it was more efficient – when set up – but sadly that dropped off with use so may as well been gears.
One curious thing is that there was no real problems with explosions. Hardly surprising really batteries have been gassing around in cars for donkeys years. The stuff disperses very easily. At one point there were some melt downs. Some of the batteries were fitted with gassing detectors to control the charging. It's easy to turn the mix of hydrogen and oxygen that comes off charging batteries back to water, it's the perfect mix so just throw a match into it and bang. It's a super high explosive and leaves a tiny drop of water. There are these things called recombiners that do this slowly but no one would trust them, the bit that slows them down might break. No one had any idea why this mechanical gas flow detection device was causing batteries to burn so it was dropped. The whole idea was to reduce water loss during charging to a minimum as topping up was painful. It's interesting to see that they fitted some sort of auto watering system. At gas detector time and long after the water loss was such a problem that the batteries were not being fully recharged and that wasn't very good for them at all.
Actually the auto top up would concern me. It looks remarkably like a very early one.
The guy who has removed the battery pack aught to build himself a hover pallet – literally a purpose built hover craft. They can be got in and out with ease with that and the air pressure needed was surprisingly easy to generate with a fan. The general manager of the project was into flying his own hover craft so it was a popular idea as a solution to that problem and worked well and cheaply.
A domestic charger was also produced that came with a 3 pin plug. It drew exactly 13 amps with a unity power factor. They found that few UK sockets could actually take the load. MK sometimes did and that was about it. It took way too long to charge the battery pack anyway.
The controller reliability was awful for many years. When I started there I used to joke that the service people should wear a mexican style bandolier loaded with those rather large and very expensive fuses that can be seen. I also made myself very popular by asking the general manager how the hell one department could decide to use gold plated pins on a plug and another normal tin on the socket. That and one or two other things lead to a much appreciated career change.
The motor that drove them was a wonderful piece of work. They used separate field and armature excitation and clever analogue feed back to avoid the need for any sort of speed sensor.
They look like thyristor controller to me as well. Sounds like the effort to get them reliable did pay off and the Chloride transistor one died off even when Chloride owned the lot. Actually with the other kit needed around them a number of aspects were way way ahead of their time.
Could every one run one ? No way. The planet hasn't got enough lead for that sort of battery.
