Hi, after buying a DRO and a couple of glass scale optical encoders in January last year at a good discount from ARC, I finally finished installing them yesterday. The X travel one was pretty much straight forward and is mounted at the front of the table, leaving enough gap to still have the stops to use. The lever type gib locks were removed anyway as they had a tendency to be in the wrong place and jamming while moving the table forward in towards the column, these were replaced with 40 X 8mm set bolts with the ends of the threads turned off and rounded much like the lever locks.
The reading head was attached with a couple of short stand off's, which should help any build up of swarf between the head and the two part brass bracket the fixes it to the Y travel, the upper part being held by the socket head bolts that hold the stop plate on.
The Y mounting was a bit more challenging. Two pieces of 40 X 40 X 5mm Aluminium angle were made and bolted on each side of the left hand end of the table, which carries another bit 90 degrees to the table and close enough to the saddle, to allow maximum X travel to the right.
Another piece of 40 X 40 X 5mm Aluminium angle was then attached back to back, so to speak, which carries the Y encoder, having it this way round will help the encoder being showered with swarf and any cutting oil. Two off cuts from the other bits of angle that made the brackets were used to pack the DRO away for bolting the two pieces of angle together, after using a DTI to set it to travel in a level plain and then drilling the other holes through.
A bracket was then press up from a piece of 6mm Aluminium plate, to secure the Y reading head in position and was fixed in place.
The cables were then secured with P clips, the X one along the top of the Y angles and then both onto a piece of second hand 50mm wide cable tray behind the machine and a small bracket of this tray was made, just to hold the loop of the X cable from sagging.
Finally the cables were carried onto another piece of cable tray fixed to the adjacent wall and up to the DRO.
All I want to do now is make and fit a protective cover for the X encoder to stop swarf and cutting oil getting on to it.
Regards Nick.
Edited By Nicholas Farr on 26/07/2020 18:11:39
