I have a Warco VM-16 which is a year old. The other day I tried to switch it on and nothing happened.
Checked the obvious, plug fuses- all fine. Delved a little deeper and had a look inside the control box. Once I got over the initial shock (no pun intended) of just how much wiring there is, I was able to determine that there was power to the front panel as far as the push to start button, the relay which I would normally here latch is silent. The circuit diagram is not much help and to be honest although I can work out simple circuits the wiring and control systems on the Warco are beyond my understanding.
I have tried and failed to make contact with Warren Machine tools by various means without success, this is disappointing as I believe when the fault occurred when the machine was still under warranty.
Has anybody had a similar experience or can any of the more electronic savvy enlighten me as to what the problem may be?
