Warco Minor mill/drill
Home Forums Manual machine tools Warco Minor mill/drill
Viewing 25 posts - 1 through 25 (of 31 total)
  • #487871
    Andrew Jenkins
      @andrewjenkins71937
      Hello everyone
      Newbie alert! I have searched but not found on this forum info on whether the above named machine is any good?
      I should point out I havent got it yet as its in storage, belongs to my brother who moved and as yet hasnt got his new workshop built! so any thoughts on this machine good or bad as I cant afford a different one!
      Andy
      Andrew Jenkins
        @andrewjenkins71937
        #487931
        Dave Halford
          @davehalford22513
          It's a round column mill with an awkward 3 pully belt drive, just ensure you don't need to move the head in the middle of a job. However it will drill and it will mill with a suitable milling cutter holder (not the drill chuck)
          As you say "I cant afford a different one!" so it's fine.
          #487940
          Nicholas Farr
            @nicholasfarr14254
            Hi Andrew, you may find this useful Warco Minor review.
            Regards Nick.
            #487959
            Adrian 2
              @adrian2
              Hello Andy, I have a Warco Minor, the round column can be a pain but there are work arounds. A DRO on the quill is
              a must. Over all I am happy with it . It is solid and I have done some useful work with it. The build quality is better
              than some later offerings. Being able to swing the head around can have its advantages when working on a large
              job. Go for it.
              Adrian.
              #487960
              Mick Dobson
                @mickdobson
                Hello Andy,
                I had one of these bought (new) in about 1994. It was a decent machine and quite sturdy, probably more so than the smaller ranges of dovetail machines on offer. The mil has reasonable capacity as well.
                The round column is a limiting issue if moving the head between cuts when you need to go back to the same reference. I sold it on in 2008 and got a Super Major with dovetail column and powered head rise/fall etc.
                Good luck, Mick
                #487961
                BC Prof
                  @bcprof
                  Hi Andrew
                  A clone of the minor was my first milling machine . The manual was interesting " Please not to be installing the complex machine in a sunshine place " was the first instruction !. They are good , solid and heavy machines . Yes ,as others have said in the past about round column, mills they are a pain if you have to adjust the head but any mill is better than no mill so go for it
                  #487966
                  Russ B
                    @russb
                    Just my 2 pence, I think they're very good machines, I much prefer the reliability and pure power of the belt drive system to that of an electronic drive.
                    They're substantial enough to make good quality cuts on small parts, and certainly have the power, 2 points which can't be said for a lot of other similar sized machines.
                    Sure the round column means you lose x/y ordinates if/when you have to lower the head, but it's not hard to pick them up for the occasional times it has to happen, and with carefully selected tooling (mainly a set of stub drills) it's rarely an issue.
                    I can't think of a better machine for the price and sq footage, but thats all very personal, I don't need atom splitting accuracy, I like the power and reliability and heavy duty'ness of it.
                    * I should point out, there are 2 different sizes of this machine, they both look the same but next each, completely different, both capable, both solid. Some have plain tables with keep plates, some (most) have dovetail with tapered gibs. some have 8 speeds, some 10, some 12 etc. The older ones seem to have a better fit and finish than the newer ones I've had my hands on although I've owned 3 or 4 of the old ones, I've never owned a newer one so hard to pickout exactly why, could just need tweaking and setting up these days.
                    Edited By Russ B on 28/07/2020 13:04:19
                    #487973
                    Bazyle
                      @bazyle
                      Again a user endorsement as it is a very good machine for hobby use and capable of anything you need to do on a 5in gauge loco for instance. Plenty of range on the z axis if you plan ahead far enough to put the head in the right place at the start, the danger is just being lazy or impatient to start.
                      One small problem not normally mentioned is that if you take too heavy a cut sideways the head might rotate so make sure that such a movement moves the cutter away from the work. Tends to happen when you forgot to properly tighten both bolts on the head after a move.
                      #488040
                      Howard Lewis
                        @howardlewis46836
                        I have owned it smaller sister, a RF25 (Economy ) for many years.
                        My solution to the loss of co ordinates when moving the head on the column was to follow Stan Bray's advice and install a bracket on the head into which a cheap DIY shop laser can be inserted, snugly. When you are happy about the position of the head, relative to the table, switch on the laser, Draw a line on the wall furthest from the machine where the beam falls.
                        DON'T look at the beam!
                        If you reposition the head so that the laser line always falls on the line on the wall, you should maintain a reasonable alignment.
                        Over ten feet any error should be of the order of 0.001", which should suffice for most work.
                        Don't overtighten the bolts for the internediate pulley carrier, to prevent cracking the casting.
                        If the pulleys are not aligned (motor in particular ) belt life will be shortened.
                        If the NVR switch buzzes, try tightening the securing screws! It worked for me.
                        HTH
                        #488326
                        Andrew Jenkins
                          @andrewjenkins71937
                          Hi Dave
                          Apologies for the late reply.
                          Posted by Dave Halford on 28/07/2020 09:53:26:
                          I'll bear that in mind.
                          Andy
                          #488328
                          Andrew Jenkins
                            @andrewjenkins71937
                            Hi Nicholas
                            Apologies for the late repl.
                            Posted by Nicholas Farr on 28/07/2020 10:41:28:
                            Regards Nick.
                            I'll read that later!
                            Andy
                            #488329
                            Andrew Jenkins
                              @andrewjenkins71937
                              Hi Adrian
                              Apologies on the late reply.
                              Posted by Adrian 2 on 28/07/2020 12:09:25:
                              job. Go for it.
                              Adrian.
                              I'll look into a DRO in the future when I get the machine.
                              Andy
                              #488330
                              Andrew Jenkins
                                @andrewjenkins71937
                                Hi Mick
                                Posted by Mick Dobson on 28/07/2020 12:16:46:
                                Hello Andy,
                                Good luck, Mick
                                Nice to see they can last for more than a couple of years!
                                Andy
                                #488333
                                Andrew Jenkins
                                  @andrewjenkins71937
                                  Hi Russ
                                  Posted by Russ B on 28/07/2020 12:58:14:
                                  I'm not sure of the exact model my brother has but good to know that there are different 'Minors'.
                                  Andy
                                  #488335
                                  Andrew Jenkins
                                    @andrewjenkins71937
                                    Hi Bazyle
                                    Posted by Bazyle on 28/07/2020 13:55:37:
                                    Again more useful information from experienced users to help a novice like myself!
                                    Andy
                                    #488336
                                    Andrew Jenkins
                                      @andrewjenkins71937
                                      Hi Howard
                                      Posted by Howard Lewis on 28/07/2020 20:36:30:
                                      HTH
                                      Again more useful user experince info for me to glean!
                                      Andy
                                      #488338
                                      Andrew Jenkins
                                        @andrewjenkins71937
                                        Again thanks to all the above for taking time to reply!
                                        Any body know how to multi quote? laugh
                                        Andy
                                        #488340
                                        Speedy Builder5
                                          @speedybuilder5
                                          I too have the Economy Mill – can be a pain changing from slow to fast speeds. I keep a second motor belt on the machine. The lower belt is used for high speeds whilst the higher belt is removed. For slow speeds, the lower belt is slipped off the pulleys and laid on the lower belt guard out of the way of the pulleys. The higher belt is slipped on for the lower speeds.
                                          Ov course a variable speed motor would help, but that is increased cost etc etc (and another potential source of problems).
                                          #488343
                                          Andrew Jenkins
                                            @andrewjenkins71937
                                            Hi Speedy
                                            Posted by Speedy Builder5 on 30/07/2020 20:27:10:
                                            Thanks for another useful tip! As you say a variable speed motor would be very useful but beyond my budget for now, maybe if i win the pools! laugh
                                            Andy
                                            #488356
                                            peak4
                                              @peak4
                                              I'm broadly with Adrian 2 on the ability to swing the head on the round column, whilst it can be a pain, it also has a major advantage for those of us who do jobs which are too big for our machines.
                                              I don't have the Warco you hope to receive, but have a Dore Westbury, which also has a round column.
                                              I've just been recommissioning a Herbert grinder, and wanted to mill a flat on a casting which was longer than the travel on the table, by several inches.
                                              By swivelling the head from one side to the other, I was able to complete the job without needing to move and re-clamp the workpiece, which would have been something of a nightmare as it's bigger than the mill table.
                                              Swung to the left;Herbert Junior Surface Grinder recommissioning.
                                              And swung to the right;
                                              I also have Centec, with a more conventional dovetail column design, but could never have done the job on that at all.
                                              Do enjoy your new toy when you get it; if your first efforts don't go to plan, don't get disheartened; just come back and ask more questions.
                                              Bill
                                              Edited By peak4 on 30/07/2020 21:49:57
                                              #488398
                                              not done it yet
                                                @notdoneityet
                                                Posted by Andrew Jenkins on 30/07/2020 20:59:14:
                                                Hi Speedy
                                                Andy
                                                No need for a big win on the pools. Second hand motors often come up on epay.
                                                Item number: 363058563347 is simply an example I just found. Same for inverters. You just need to bide your time, for purchases that are not imperative at the immediately present time.
                                                #488546
                                                Andrew Jenkins
                                                  @andrewjenkins71937
                                                  Hi Bill
                                                  Posted by peak4 on 30/07/2020 21:47:37:
                                                  Bill
                                                  Good to note that every design has its advantages aswell as disadvantages and thanks I will!
                                                  ANDY
                                                  #488548
                                                  Andrew Jenkins
                                                    @andrewjenkins71937
                                                    Hi Speedy
                                                    Posted by not done it yet on 31/07/2020 07:17:52:
                                                    Hi Speedy
                                                    Andy
                                                    Point taken!
                                                    Andy
                                                    #488672
                                                    Robin
                                                      @robin
                                                      I have the Warco Major RF something or other, I think it cost me £700 back around 1990.
                                                      There is a rumour that RF stands for Rong Fu, is that true or am I not getting a joke?
                                                      I am good at not getting jokes smiley
