I had a touch/feel of a 550 ( if you'll pardon the expression….) at the last Harrogate show…..After several failed attempts to get some attention, one of the Warco guys took my details and said my name would be added to the list.
Anyhow, I looked at several other machines inc the Chester offerings both off and on line, ended up with the SPG machine I have now….
What I didnt like about the 550 was :
No seperate fed shaft for power feed- powered by the lead screw….
Location of the saddle feed/cross slide fed lever
The camlock for the tailstock, handle position ….and generally how it had been implemented….
Flange fit for chucks ( the SPG lathe is Camlock….much better imho…)
Implemenation of speed change messing about with belts….( my SPG now sports a vfd and 3 ph motor… After replacing the existing dc drivetrain)
Bed length is only 550 ( mine is 700..)
Price…..( paid less than £1900 inc vfd/motor which I added)
(If I were to write an appraisal of the SPG machine it would be very biassed…..all I can say is I'm pleased with it)
