Hi Otley.
I have a Chester crusader de luxe . It is now 9 years and I have owned it for 4 years. Like all eastern made lathes its a bit rough. The handles are all locktited in place as tightening alone did not stop them from coming loose. There is a leak some where from the gear boxes as the spillage tray is always wet with oil. The spillage tray itself does not empty when using coolant and the tray is silicone sealed to make sure that does not leak around the headstock. The indents on the gear change handles are poor. Many a time I have not located them correctly and crashed the gears. The gears are noisy as is the main drive. I run with slightly thicker oil to try to help keep it quiet.
The chucks are oversize. I have bought new backing plates and added burned chucks with sensible sized jaws so I can hold parts correctly.
The cabinet doors are alway a fight to open as they are poorly made.
The cross slide unwinds itself during turning so the gib strip is over tight to stop this happening.
I could go on moaning.
I had a 5" Boxford from the late 70's which I sold before buying this thing. I am now looking for another as the crusader is not very good at all.
