Warco GH Major mill
Warco GH Major mill
Home Forums Manual machine tools Warco GH Major mill
  • #138518
    Deric
      @deric
      Seasons greetings
      Has anyone with a warco GH Mill got/had and solved the 'floppy' and inaccurate down feed levers?
      The handles on my mill rattle about so badly that there is no definite engagement or disengage and will quite often disconnect when down feed is in use, most annoying!
      I can't have the only one with this problem just hope someone can help
      best regards
      Deric
      Deric
        @deric
        Drill down feed levers.
        #138521
        michael cole
          @michaelcole91146
          Hi Deric
          Are you talking about the course or fine downfeed. I have a Chester Lux mill, which I belive is the same as a Warco GH mill but have never had a issue with the downfeed levers.
          #138522
          Deric
            @deric
            Michael, it's the main handles/levers, there are two on the ' hub' which have to be pushed to the right to engage the down feed. Any vibration when using power down feed will cause them to'jump out of gear' and the quill flies back up!
            i just had a look at the Chester lux and if yours is the same it has three handles on the main down feed. My machine is circa 2008 and it looks like on the warco machines that the down feed has been changed to the 3 handle version like yours.
            i would be interested to know how you engage fine down feed
            Deic
            #138524
            michael cole
              @michaelcole91146
              Without going and looking at it, but quickly, On the hub with the 3 handles for the course downfine is a screw lock which moves from fine to course feed. I do not have the power down feed so may be different to yours.
