W “scale” of oils
W “scale” of oils
Home › Forums › Beginners questions › W “scale” of oils
Viewing 15 posts - 1 through 15 (of 15 total)
  • #8339
    Nitai Levi
      @nitailevi73768
      #261671
      Nitai Levi
        @nitailevi73768
        Hi
        A newbie question… I see oils in the chart for my lathe. I don't have a problem with the oils themselves and the correct ones to use since I already have them. There's something that is confusing me in general that I'm trying to understand.
        Just as an example, one part needs either SAE 70W gear oil or SAE 10W crankcase oil. This suggests they are roughly the same viscosity. I also found 10W gear oil, which is obviously different from 70W gear oil and I assume also from 10W crankcase oil.
        Are there are two (or more?) "scales" of W numbers that mark viscosity depending on the type of oil? So if a spec says xW without anything else, it could actually mean very different viscosity depending on the type of oil, right?
        Thanks
        #261677
        Hopper
          @hopper
          Yes. Gear oils use bigger numbers to denote the same viscosity. EG, 90 weight gear oil is about the same viscosity as 20w/50  engine oil. ISTR this was done to stop enterprising mechanics from using gear oil in engines and vice versa because they had the same weight rating. The additives in the two types of oils are different and not compatible so the twain should never meet.
          Other oils' viscosities are rated by an ISO rating, such as ISO 32 or 64. Equvalency charts are on the net. Usually these are hydraulic or machine oils.
          To add to the confusion, the W in multi-grade oil ratings such as 20W50 but instead stands for Winter. It means the oil behaves as a 20 weight oil in winter conditions eg 0 degrees C but has the effective viscosity, due to additives, of a 50 weight oil at 100C temps.  But everyone calls it Weight so its one of those things that has gone by the wayside except for a few hardcore pedants.
          Edited By Hopper on 18/10/2016 12:13:46
          #261683
            Morning Nitai
            I think the SAE numbers used to specify motor oil are not comparable with the similar SAE numbers used to specify Gear Oil. In practice, SAE10W and SAE70W have similar viscosities:
            • SAE10W Motor Oil – 4.1 sq/mm per second at 100C
            • SAE70W Gear Oil – 3.9 sq/mm per second at 100C
            I think the 'W' stands for Winter and means the specification covers low temperatures, i.e the oil won't thicken unreasonably in cold weather.  (Edit: Hopper posted first, see his comment on the W)
            Edited By SillyOldDuffer on 18/10/2016 12:13:02
            #261687
            Paul Lousick
              @paullousick59116
              On the subject of oil types.
              What is recommended for lubricating lathe slides, headstock spindle, shafts, gearbox, etc.
              Paul.
              #261708
              stevetee
                @stevetee
                So how are we to tell that a gear is a gear oil? The numbers EP at the end of the specification that's how , and therin lies the rub. A gear oil behaves like an oil with a viscosity of 70 , 90 or what ever under conditions of extreme pressure. however when it's not under extreme pressure , then it behaves like an oil of whatever viscocity it's made of , which is not stated. More modern gear oils , usually to GL5 spec are multi graded, many older gear oils are mono grade oils. I had a tin of SAE 140 which went in an old Villiers motorbike , it was incredibly viscous and was like pouring golden syrup. EP90W140 pours like a motor oil.
                Universal tractor oil is suitable for engines and gearboxes, but is quite low specced in comparison with modern motor or gear oils.
                #261744
                Thor 🇳🇴
                  @thor
                  Hi Paul,
                  I use a way oil like Shell Tonna 68 or Mobil Vactra #2 to lubricate the ways on my lathe and slides on my milling machine. Both Chronos and ARC can supply way oil. For the gearbox (and apron gears) Mobilgear 627. For headstocks that use oil lubrication many lathes use a so called Hydraulic oil. Check your lathe manual.
                  Thor
                  Edited By Thor on 18/10/2016 17:04:15
                  #261773
                  not done it yet
                    @notdoneityet
                    ,The numbers EP at the end of the specification that's how ,
                    Just not true. EP (extreme pressure) grades are for things like anything but straight spur gears! Most EPs are limited to use where there are no 'yellow' metals present. Go figure!
                    The 'W' rating really relates to cold oil and the other to normal operating temperatures. Nothing more, as it means that the oil will not congeal (and not pump/circulate) at starting temperatures for an engine, provided the minimum temperature is adhered to.
                    I doubt that any gear oil has a 'W' rating? It would mean the gears were just lubricated by 'grease'!
                    #261775
                    stevetee
                      @stevetee
                      "I doubt that any gear oil has a 'W' rating? It would mean the gears were just lubricated by 'grease'!"
                      and so on .
                      #261780
                        Posted by not done it yet on 18/10/2016 20:17:01:
                        I found this in a technical report:
                        "Each low temperature gear lubricant (SAE grade followed by a W) must not exceed a maximum viscosity of 150,000 cP at the temperature indicated. A 150,000 cP fluid appears like a semifluid grease which will barely pour."
                        The background to the paragraph states that damage occurs when a Gear Oil becomes more viscous than 150000 cP. As this could occur during winter in a cold country the use of W grades is recommended. In hot countries a W grade oil is unlikely to be needed, though I guess there's no reason why one shouldn't be used.
                        #262137
                        Nitai Levi
                          @nitailevi73768
                          Posted by Hopper on 18/10/2016 11:57:00:
                          Wouldn't that theoretically create even more of a problem, such as someone buying the incorrect oil with the wrong viscosity, because they wanted e.g. 10 and got 10 of the other type, which was completely different?
                          At least I understand how it works and there's a pretty good chart. I used mostly ISO and talked with the oil manufacturer that I buy from and they can understand.
                          Thanks everyone
                          Edited By Nitai Levi on 21/10/2016 05:29:39
                          #262200
                          Ian S C
                            @iansc
                            I can't remember the proper numbers but in aviation work we used Aero Shell W-100, and W-80 these were detergent oils used in aero engines, a caution goes with these oils "DON'T mix with non detergent oil. What happens? Early 1950s RNZAF Hastings Mk 3 transport aircraft at Singapore, refueled, and oil filled by RAF ground crew, filled with straight oil, the result of the mixed oil was that all 4 engines stopped just after take off because the oil foamed on mixing. The RAF used Mk 1 and 2 Hastings with earlier engines, and straight non detergent oil.
                            Ian S C
                            #262203
                            Bill Davies 2
                              @billdavies2
                              Years ago, I helped a friend rebuild an AC Greyhound. When refilled and run with motor oil, the oil went silvery, which we put under a microscope,and could see the fine particles. Contacting various manufacturers, Morris of Shrewsbury suggested a 'straight' oil without additives, and everything was fine after that. With hindsight, I could imagine that some part was bedding in, but there was no subsequent evidence of wear.
                              Bill
                              #262204
                              Hopper
                                @hopper
                                Posted by Nitai Levi on 21/10/2016 05:28:59:
                                I believe it was more for working mechanic shops where they would have a stock in the workshop of 30 weight or 40 or even 50 weight etc engine oil. Their stock of gear oil would have been 90 weight gear oil. So, supposedly, there was less temptation to use gear oil to top up an engine, or engine oil to top up a gear box if supplies of the other ran out. If they more correctly labelled the gear oil as 50 weight or whatever its viscosity really was, it may have ended up in somebody's engine.
                                I don't know where I know this from, just one of those things floating around in the back of my mind. I think it was done way back early 20th Century when car mechanicing was a new profession.
                                #262273
                                Dave Halford
                                  @davehalford22513
                                  When someone say 30 weight oil they are referring to sae30 the W should only be used for multigrade oils.
                                  You can easily tell any gear oil – it stinks
