Turning aluminium with carbide inserts
Home Forums Beginners questions Turning aluminium with carbide inserts
  • #391876
    not done it yet
      @notdoneityet
      Vic,
      Read Andrew’s post just above yours. That should make it clear enough.
      John Reese
        @johnreese12848
        Vic,
        You could grind a chipbreaker into the tool but I doubt it would work well. Wrought aluminum doesn't break up for me. I notice the polished inserts for aluminum don't have a chipbreaker. Cast aluminum does break chip fairly readily. Unfortunately the high silicon content dulls HSS quite rapidly.
        #391946
        John Reese
          @johnreese12848
          Vic,
          Something I forgot to mention: the way a tangential tool is positioned it might be difficult to get an effective chipbreaker. There is a very small clearance angle on the tool. If you ground a groove for a chipbreaker I suspect there might be interference between the ridge behind the groove and the work. Be advised that my conclusion was arrived at in my recliner, not in my shop.
          #392118
          Anonymous
            Posted by Vic on 19/01/2019 12:11:41:
            …..have any of you milled HSS tool bits with a carbide end mill? Just wondering if it's preferential than grinding the initial shape in some cases?
            Yep:
            Involute form milled on the end of a 1/4" square HSS toolbit with an uncoated 3-flute carbide cutter, for use with a slotting head to cut an internal gear. Relief and rake angles were ground by hand afterwards.
            If I need to remove a lot of material to get the required shape I'll rough out with a carbide cutter to start with. Way quicker than grinding.
