triple start tap die
Home Forums Workshop Tools and Tooling triple start tap die
  • #17686
    capnahab
      @capnahab
      capnahab
        @capnahab
        Does anyone know where to purchase specialist taps ?.
        I need a triple metric 12mm x 0.75 , – its for a pen top. The specialist pen turner suppliers in the US but can't find anyone in the UK.
        Edited By capnahab on 21/04/2015 20:23:22
        #187285
        Roderick Jenkins
          @roderickjenkins93242
          Sorry, just noticed the triple start!
          Rod
          Edited By Roderick Jenkins on 21/04/2015 20:22:27
          #187286
            Rod, its a triple start one that he is after, not even Tracy's have them
            #187288
            Roderick Jenkins
              8 seconds too slow in editingblush
              #187289
              capnahab
                @capnahab
                sorry , my fault , should have put it in body, have done so now. Some of the penturners forms have had group buys for a specialist order but not at the mo.
                #187291
                Bob Brown 1
                  @bobbrown1
                  This lot make "specials" **LINK** may be worth a telephone call.
                  Bob
                  #187297
                  Oompa Lumpa
                    @oompalumpa34302
                    Posted by Bob Brown 1 on 21/04/2015 20:30:05:
                    Bob
                    A really nice, genuine chap. But kept me on the 'phone for twenty minutes chatting and sometimes this can be frustrating. I emailed him last week but I don't think he "does" email very well.
                    I need an 6×48 tap and this is an arse of a thread. I can get them in the US but one tap works out at twenty quid by the time it gets here So I will just take a chance he is busy too tomorrow
                    graham.
                    #187301
                    Ian P
                      @ianp
                      Posted by Oompa Lumpa on 21/04/2015 20:49:34:
                      graham.
                      Can I be the first to ask, what is a 6×48 tap?
                      Ian
                      #187303
                      duncan webster 1
                        @duncanwebster1
                        why not screw cut it?
                        #187305
                        capnahab
                          @capnahab
                          Because I am not good enough at cutting an internal triple start m12 x 0.75 thread in a blind hole ( without wrecking the work piece) in which I have invested some time.
                          #187310
                          Oompa Lumpa
                            @oompalumpa34302
                            Posted by Ian Phillips on 21/04/2015 22:00:56:
                            graham.
                            Ian
                            Ah, yes. I was confused with this too the first time I saw it. The 6 refers to wire gauge and of course it is 48 TPI.
                            Or so it was explained to me.
                            graham.
                            #187317
                            I.M. OUTAHERE
                              @i-m-outahere
                              Depending on what material you are cutting i wonder if you could make your own from silver steel ?
                              Then use that home made tap to make a die for the male thread ?
                              Just a thought.
                              #187321
                              Clive Hartland
                                @clivehartland94829
                                I use these type of 3 start taps on eyepiece threads and they are mostly an adjustable type of tap with a screw down the center to allow easy entry into existing threads. They are quite delicate to adjust and are very expensive from our Leica tooling section in Switzerland. I have cut one but as a solid and not adjustable and it worked fine.
                                #187324
                                  graham.
                                  Ian
                                  As said in the US for threads below 1/4" dia they use a number system similar but not the same as our swg as the numbers go in the opposite direction eg a low number is larger dia eg 10=0.190" , 6= 0.138" , 0= 0.060".
                                  Typically used for UNC, UNF and UNEF and UNS thread forms.
                                  The way to write it to save confusion is 6-48 or #6-48
                                  J
                                  Edited By JasonB on 22/04/2015 07:40:33
                                  #187326
                                    Posted by JasonB on 22/04/2015 07:38:44:
                                    Useful tabulation, here
                                      Or the more colourful one I tend to use or should that be colorful?
                                      HERE
                                      #187336
                                      Frank.N Storm
                                        @frank-nstorm18349
                                        So Mr. Capnahab wants to cut a internal 12 mm thread and for this needs a #6 tap of 0.138" ? (= 3.43 mm!).
                                        Somehow these numbers don't come out even…
                                        Regards, Frank
                                        #187339
                                          No Capnahab wants a tripe start M12x0.75 which can be bought from the US, Graham uses 6-48 which also come from the US and thats the common link.
