Solid rings necessitate multi piece, built up pistons, and will be less flexible than a ring with a gap. Alignment of the components of a built up piston, at least three with two rings, plus piston rod? may be less accurate..
If the rings have a gap, it should be possible to expand them to pass over the piston. After all, that is the method used in I C engines which are subject to much higher pressures and temperatures than a steam engine, even with superheated steam. The CLUPET ring design, although probably not easily produced in such a small size allows ring expansion whilst reducing leakage to a minimum.
The fitted gap should be 0.001" per Inch of bore diameter, to miminise leakage through the gap, and may probably accommodate any slight out of roundness that may occur in running. Since the metal sections around the cylinder are unlikely to be completely uniform, as temperatures move away from the ambient when machining took place, the bore is unlikely to remain absolutely "as machined"., and cylinder temperatures will change along the cylinder, and during running, so dimensional changes are quite possible.
