Thread pitch
Thread pitch
Home Forums Beginners questions Thread pitch
  • #99404
    pgrbff
      @pgrbff
      I recently bought an old chandalier. The candle(light) holders are threaded but a standard M10x1.0 nut would not fit. I bought a pitch gauge and they measure 0.9mm pitch. I cant find any refere nce to M10 x 0.9 pitch, nuts, tap or dies. Is this a size that may have been produced at some time?
      Where might I found some nuts?
      Should point out it is most likely an Italian chanadalier.
      pgrbff
        @pgrbff
        #99408
          25.4 ÷ 0.9 = 28.2222
          and the old 1BA thread pitch was nominally 28.2 tpi
          It is, of course, common practice to use convenient fine threads on "tubes".
          Looks like you have a standard UK fitting there; so just look for an Electrician with some old stock.
          pgrbff
            @pgrbff
            Thank you for the quick reply. As I understand it 1BA is around 5.3mm diameter. Is it possible for me to find a nut with 1BA pitch that will fit a nominally 10mm tube?
            #99411
              3/8 x 28tpi brass thread was a standard electrical thread.
              Could also be 1/8 BSP which is 28 tip and just over 3/8"  OD
              J
              Edited By JasonB on 25/09/2012 22:10:00
              Edited By JasonB on 25/09/2012 22:25:33
              #99412
              John Stevenson 1
                @johnstevenson1
                I'll go with Jason.
                Used to make some light fittings and these were, as Jason says 3/8" x 28.
                #99413
                  Agreed
                  and, as I said; friendly local Electrical shop is the place to look.
                  … failing that, it's a good excuse to poke around the Car Boot Sales.
                  pgrbff
                    @pgrbff
                    Thanks for all your replies. May not be so easy to find 3/8 28tpi here in Venice, but I may be wrong. I don't have the thread with me but I think it measured about 9.7mm OD, I guess this would be about right for threaded 3/8 rod?
                    I may have to look online.
                    Sorry I didn't pick up on the replies last night but the notifications went to spam for some reason.
                    #99436
                    pgrbff
                      @pgrbff
                      Found one nut in electrical shop, 5 to go.
                      #99912
                      pgrbff
                        @pgrbff
                        1/8 BSP, bought myself a tap and re threaded the fittings. Thanks for the help.
                        #99921
                        mick
                          @mick65121
                          When I was involved with the manufacture of light fittings the lengths of threaded tube were known as "all thread" which is M10 x1.0
                          #99923
                          pgrbff
                            @pgrbff
                            Current fittings are M10 x 1.0 but I jave found several older pices which were 1/8 BSP.
                            #99939
                            Speedy Builder5
                              @speedybuilder5
                              Uh – thought model engineers screwcut things like nuts !
