Those little screws for carbide inserts…
Home Forums Beginners questions Those little screws for carbide inserts…
Viewing 16 posts - 26 through 41 (of 41 total)
  • #434667
    Douglas Johnston
      @douglasjohnston98463
      Posted by Michael Gilligan on 25/10/2019 10:55:33:
      Posted by Douglas Johnston on 25/10/2019 10:14:38:
      The Arc Euro screws are top quality Sumitomo ones, but look at the price of them. […]
      For convenience: **LINK**
      https://www.arceurotrade.co.uk/Catalogue/Cutting-Tools/Lathe-Turning-Tools-Indexable/Sumitomo-Indexable-Turning-Tools/Sumitomo-Spare-Insert-Locking-Screws-and-Torx-Wrenches
      Thanks for that link Michael, my catalogue is clearly out of date, I see the price of the wrenches is now £9.64. I think I will need to lie down from the shock. When I bought a parting tool with 10 inserts from China recently it cost less than £5,including postage,and came complete with a very decent wrench as part of the package.
      Doug
      Nigel Graham 2
        @nigelgraham2
        I'm a happy Tracy Tools customer too!
        I don't know how their prices compare but you could also try JB Cutting Tools for replacement screws.
        I don't change tips on the machine, or even in the workshop with its solid floor impervious to all but tiny tool-holder screws, but indoors on a suitable surface on a table. (Keep the tool-holder in the QC block if necessary.)
        #439425
          My ebay purchase arrived today: **LINK**
          https://www.ebay.co.uk/itm/50pcs-M2-5-x-6mm-Insert-Torx-Screw-for-Carbide-Inserts-Lathe-Tool/283414156464
          First impressions are very favourable
          old mart
            @oldmart
            I have 1.8, 2, 2.5, 3, 3.5 and 4mm screws in stock, all bought on ebay, very cheaply. I have never had one break, but they slip from my fingers all too easily when changing inserts.
            #439441
            Boiler Bri
              @boilerbri
              I change mine over a small tray just in case i drop them. At 61 my fingers do not work as good as they should and my grip has gone. A lot of club members are a lot older than me and they will have the same problems with small items.
              Bri
              #439465
              BC Prof
                @bcprof
                I too change the insert over a small tray .The screws still try to escape by bouncing out of the tray to be consumed by the black hole AKA workshop floor. Solution, clip a small magnet to the torx driver before you start
                #439470
                Emgee
                  @emgee
                  BCPROF, simple to magnetise the torque driver, put 4 or 5 coils of insulated wire tightly around the tool and flash the ends of the wire across a 12volt battery a few times.
                  Emgee
                  Edited By Emgee on 30/11/2019 10:08:54
                  #439528
                  Enough!
                    @enough
                    Or get one of these. I've found them quite good for magnetising screwdrivers and the like …. though less good for demagnetising.
                    #439545
                    old mart
                      @oldmart
                      When your hands are as arthritic as mine, you will have trouble even holding the screwdriver.wink
                      #439556
                      BC Prof
                        @bcprof
                        old mart. I sympathise about the hands. I find the " flag" style of driver the easiest to use. The small button type magnets have a very strong magnetic field which , when they are attached to the driver, hold the screw firmly in place . I have find that the driver retains little residual magnetism when the magnet is removed hence any fine iron dust etc has no excuse for filling up the torx head. Having said that I still clean the driver and screw with a brass brush befr oe starting the job.
                        #439566
                        old mart
                          @oldmart
                          I have three magnets by the machines at the museum, one on a three foot handle, and two little telescopic ones. They are invaluable, as I have difficulty reaching as low as the floor.
                          #439568
                          John Baron
                            @johnbaron31275
                            Hi Guys,
                            A cheap source of 2.5, 3.0 and 3.5 mm coarse torx screws are old hard drives !
                            #439569
                            John Baron
                              @johnbaron31275
                              Hi Guys,
                              A quick tip ! To magnetise a screwdriver, just drag it over a magnet a few times.
                              Does not work for stainless items. smiley
                              #439673
                              old mart
                                @oldmart
                                Be careful with getting the right screws, their heads have a taper, probably 60 degrees.
                                #439689
                                HOWARDT
                                  @howardt
                                  Torx screws for inserts will have a higher tensile strength than those in use for hard drive assembly.
                                  #439702
                                  Kevin Bennett
                                    @kevinbennett25223
                                    I get 2.5mm torx from china and never had one fail and the cost is much lower and takes about 2 weeks to my door
