As said before "No soft start, its plug and play just the way 3ph 400V+ would be installed to premises." Existing control panel untouched, inverter wired direct to main on/off rotary, retaining all functions.
An inverter is a means of changing DC to AC, misrepresented as a VFD.
At the time if i could have got the remotist of help from Direct Drives, the second inverter 4kw 400V would have been used as a VFD. Months passed lathe needed pronto as other Harrison was shot no time to figure the rewiring. Motor ran ok but never tried under load with 3 sec soft start which would have been tolerable.
Might get that 4kw inverter back if i can work out the lathe functions, should do but prob is where to wire in to the inverter, manual absolutely uselss blind you with science 100 odd pages but no ref to inputs. Or buy a Machine Mart motor and another cheap inverter 220v where you can get help.
I couldnt live with a 10sec soft start for higher revs, job could have been finished by then.
Currently using a 7.5kw 3ph 400V inverter 'Plug and play' meant for running whole workshops. Only problem i get is a live to neutral unbalance so trips the main RCCD at anything starting lathe up past 540rpm.
What sort of cuts can you put on power feed running at 220v 3ph?
