Posted by Michael Gilligan on 08/01/2020 14:00:39:
Posted by Hopper on 08/01/2020 12:52:49:
It has a screwdriver slot for a reason.
You need the proper tool for the job: a simple impact screwdriver with wide, straight bit. The basic old type you rap with a hammer while twisting. Available on eBay for 15 quid. Search for Impact Driver Motorcycle.
Or take it to a local motorcycle shop and have them use theirs on it. Probably only cost you 30 quid there!
Impact driver will jar screws loose that you can never shift with a screwdriver and pliers etc. It;s the impact wot does it.
With the greatest respect to your experience and expertise, Hopper … I must beg to differ
The screw [in its present setting] should be free-running in the chuck thread: it is therefore not 'over-tightened' but 'stuck' ; so I am not entirely convinced that impact [unless, perhaps, applied repeatedly] will have the desired effect.
I am. That's what impact drivers are for: freeing stuck threaded fasteners. Works on screws ranging from 1/4" to 1" and more on 80 year old motorbikes that have sat out in the weather in some farmer's paddock half their life and on every other piece of machinery I've ever worked on. Well corroded threaded aluminium inspection plugs etc etc etc included. Yes you will often need to hammer on it multiple times.
For bigger stuff such as fork top nuts with say a 1-1/8" very fine thread, torqued to 140 foot pounds when it left the factory in 1975, I'll use a half-inch drive air impact gun hooked up to appropriate socket. Not much in the typical home workshop will stand up to that.
I'm just suggesting the hammer blow type here because of cost. And if that and/or a propane torch won't shift it, you might as well machine the thing out and buy a new one. Or maybe try filing two flats on the protruding threaded bit and turn it with a wide-jawed shifting spanner.
Edited By Hopper on 09/01/2020 12:40:42
Edited By Hopper on 09/01/2020 12:42:25
