Stuart Models Clack Valves
Home Forums Locomotives Stuart Models Clack Valves
  • #1530
    David Heah
      @davidheah47239
      Will they work with injectors?
      David Heah
        @davidheah47239
        Good evening all,
        My boiler is fitted with 5/16 x 26 clack valve mounts (presumably the maker wanted course threads to avoid cross threading, or perhaps he just had a set of BSB taps and dies!)
        Stuart Models offer a 5/16 x 26 threaded clack with 3/16" pipe connection – so a straight 'plug and play' available.
        Can anyone advise what the lift of these clacks is like, and if they are suitable for use with injectors (11oz or 3/4 pint).
        Kind regards,
        David
        #244132
        Boiler Bri
          @boilerbri
          Hi. My 5" Brittania is fitted with the same size and they work ok. If the lift is a bit tight it will increase the velocity of the. Water going in and restrict the flow a bit but should be ok otherwise.
          Bri
          #244172
          julian atkins
            @julianatkins58923
            5/16" x 26 tpi seems very big to me for a 11 oz per min injector. A check valve of 1/4 x 40 tpi connnections with 1/8" dia seat and 5/32" ball would be quite adequate.
            Cheers,
            Julian
            #244175
            David Heah
              @davidheah47239
              I am less concerned about the valve being too large; more so concerned about it being too small and causing back pressure on the injector. A decent injector should be able to create ample hydrostatic pressure to lift even a larger ball check valve.
              As I am working with an existing boiler, replacing the soldered bush would precipitate further inspections and generally unnecessary work – I'll place an order with Stuarts. Thanks Boiler Bri for your confirmation on this application
            Home Forums Locomotives Topics
