‘STIFF’ Compound Slide
Home Forums Beginners questions ‘STIFF’ Compound Slide
Viewing 3 posts - 26 through 28 (of 28 total)
  • #800319
    kevian64
      @kevian64
      UPDATE
      I’ve read and re read all your very welcome and appreciated comments and taken the plunge. I’ve removed the slide, disassembled same, removed all swarf and gunge, cleaned with wd40, rubbed down with fine steel wool and wiped clean. I applied lubrication oil and then reassembled. It’s now approximately the same ‘stiffness’ as the cross slide and I’ve even managed to remove the ‘play’.
      Thanks very much everyone, I’m over the moon and my lathe still works 😀
      Kev
      Howard Lewis
        @howardlewis46836
        Success!
        Just what you wanted, and you have gained a little experience and confidence whilst solving the problem, and improving the machine
        #800389
        Pete
          @pete41194
          Congratulations Kev 😀
