Seig C0 baby lathe
Seig C0 baby lathe
Home › Forums › General Questions › Seig C0 baby lathe
  • This topic has 12 replies, 10 voices, and was last updated 1 June 2025 at 09:26 by Robert Atkinson 2.
  • #800349
    msrt7mcfl7
      @msrt7mcfl7
      I’m thinking about getting one of these, it’s a perfect size for my tiny workplace.
      The only thing that’s stopping me it lack of auto feed and screwcutting, I’m aware that you can get an auto-feeder addon which I would get at a later stage.
      Being new to this would the auto-feed allow the machine to cut threads?
      #800355
        In principle, you would have a first step on the road to cutting threads … but you would still need to implement the appropriate reduction-gearing for the various pitches [this can be done either electronically or mechanically] AND replace the belt  with something synchronous !
        All do-able, but quite a project.
        https://www.facebook.com/siegind/videos/c0-automatic-feeder-installation/3654165684707691/
        #800360
        msrt7mcfl7
          @msrt7mcfl7
          Thanks for the information, a project like that would be far from my skillset at the moment. The C2 has that capability but space is quite limited at the moment.
          Would it be feasible to just use die&taps with the machine, I might be worrying about a feature that I can manage without.
          #800361
          Wink Hackman
            @winkhackman25989
            If you only want to thread small sizes, say up to 8mm, taps and dies are absolutely fine. It’s easier if you have a  tailstock die holder and a handle to turn the spindle manually.
            #800375
            Howard Lewis
              @howardlewis46836
              For a lot of the work that you are going to do, Taps and Dies should suffice, but otherwise, for cutting threads, or auto feeding, you need changewheels.
              You can learn to use both hands to rotate a handwheel, slowly and steadily, for a fine feed; but you can’t screwcut threads by hand!
              Changewheels come with the C1, (so you could auto feed or screwcut) but it does not seem to be imported into UK any longer.
              You might be able to find a secondhand one.
              Even with a C1, you are unlikely to be screwcutting large threads (The motor will probably have insufficient power, and overloading it endangers the motor and the control board!)
              The C2 / C3 operator manual says that a 0.25mm (0.010″) cut should be regarded as a roughing cut, And that has a motor of less than 0.5Kw.
              You wouldn’t like the cost of one or more taps to make shade rings for lamp holders (28 x 2 or 28.5 x 1.25), just to make one or two!
              #800380
                The C0 uses a belt to give the auto feed so does not need changewheels. Similar arrangement to a Unimat 3 which it is a copy of.
                Taps and dies will do for what you are likely to be able to make on teh C0, I did a Stuart 10V on my U3 so it should be upto that sort of work.
                Not something you would want to do all the time but if anything like the U3 then a deeper cut is possible
                #800393
                Peter Cook 6
                  @petercook6
                  Sherline offer a screw cutting add-on for their range of micro lathes, but no longer do a power feed attachment. Taig lathes can be had with power feed, but no screw cutting capabilities.
                  I use a Taig (with a home brewed power feed), and so far in the seven years I have had the lathe I have managed fine with taps and dies (and occasionally a bit of ingenuity using threaded rod and bolts) for the threads I have needed. To some extent it depends on what you plan to make.
                  The Sherline, like the Seig would be ready to go out of the box, the Taig is probably more of a project. There is a lot of information available online about people who use them both, with lots of ideas and designs for add-ons.
                  #800401
                    I had another dig-around
                    This looks like a viable alternative approach
                    https://youtu.be/QCP-pEzeMu4?feature=shared
                    … Just replace his simple control box with an ELS unit and screw-cutting is GO
                    [no change-wheels required]
                    Hollowpoint
                      @hollowpoint
                      May I suggest that you take a look at a second hand Cowells lathe. The ME90 is approximately the same size but has superior build quality to the C0. It also has power feed, screw cutting, back gear, taper turning compound, off-settable tailstock and a t-slotted slide!
                      Of course they are a bit more expensive. A sieg C0 is currently about £500 new and a used cowells ME90 will likely be £600-1000.
                      #800579
                      Mick B1
                        @mickb1
                        I have a Sieg C0 with the power feed attachment. I still use it occasionally for small parts if there’s a setup on my Warco WM250V that I don’t want to disturb.
                        The power feed’s a *very* basic accessory. All it does is use a drivebelt to rotate the leascrew to drive the carriage. It’s a fixed ratio so you have a single feed rate per rev. You could theoretically turn up different sized pulleys to achieve different rates but that’d be fraught with other issues relating to belt tension. Nevertheless it can save time and effort turning longer diameters.
                        Effectively threading can only practicably be achieved with taps and dies, and in any case larger threads requiring expensive ones would be beyond its reasonable capacity.
                        I also a made a Stuart 10V on a U3 I had in the past. The C0 isn’t as “nice” as the U3 but it is a little more powerful, comes as a ready-use installation with splashback etc., and will do similar work. I bought the C0 when I too had extremely limited space and I’d say it did what I could reasonably expect of it, and I wouldn’t lightly dispose of it now I have it.
                        #800604
                        msrt7mcfl7
                          @msrt7mcfl7
                          Thank you all for the replies, especially  michaelgilligan. I have a fair few 3d printers and using a stepper motor to drive a feed seems like a good way to do it (and I have plenty of spares)
                          I’m going to search for the fabled C1 and see what is about, another lathe that would be in budget and also fit on the worktop would be an optimum TU 1503V. I’ll probably end up getting the C0 as they’re quite a good price getting them directly from germany.
                          thanks again.
                          #800776
                          Sonic Escape
                            @sonicescape38234
                            Not auto-feed related topic, but I would suggest if possible to check the C0 chuck before buying it. I have an early 2000’s Axminster model and the chuck is horrible. No amount of cleaning or lubrication seems to make it work properly. Nothing is square and it is clamping more with the bottom part. And the only decent 14×1.4mm replacement chuck that I’m aware is the very expensive one from Sherline. I hope 20 years later they make better baby lathe chucks.
                            #800805
                            Robert Atkinson 2
                              @robertatkinson2
                              If you have a spare stepper and driver have a look at this:
                              1 axis ELS
                              I bought one for my ML7 and am very impressed with it.
                              Edit. Forum added an image. Weird. The link is at the bottom of the image.
                              Robert.
