Stainless steel shaft
Home › Forums › Beginners questions › Stainless steel shaft
  • #82257
    Clive Hartland
      @clivehartland94829
      I have just bought some stainless steel 5mm shaft and its not round, put in the triple plain bearings and it catches as it is turned.
      Measuring it shows a slight ovality but its hard to measure.
      Does anyone know of where I can get precision ground 5mm st steel shaft?
      I have looked at HPC but no luck there.
      #5872
      Clive Hartland
        @clivehartland94829
        #82259
        jason udall
          @jasonudall57142
          maybe
          smiths metals? Poole 01202893712
          RS? 01536 201201
          Rs may be better free del.
          Smiths cheaper by foot but add carr…
          #82260
          Weldsol
            @weldsol
            You could look at the CNC parts suppliers as they offer stainless for the linear bearing shafts. The only thing is it’s very hard but is machineable with carbide tipped tooling
            Paul
            #82261
            S.D.L.
              @s-d-l
              Its a common problem with center less grinding and needs a mic with a vee anvill to detect as it can measure the same at any position with a std mic.
              See here.
              And here
              You might be able to detect in raw stock by rotating in a vee block with DTI mtd.
              Steve Larner
              #82263
              Clive Hartland
                @clivehartland94829
                I will look at the RS cat. tomorrow at work, thanks for your help.
                #82265
                jason udall
                  @jasonudall57142
                  other smiths msybe local to you.
                  #82267
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    Hi Clive ,
                    Please note that while 5 mm ground bar is available from several stockists its is only actually manufactured in a very few places . I and others have had the experience recently of chasing similar requirements and ending up with more and more samples of the same dud material after each enquiry .
                    Personally if the length needed is not impossibly great I always prefer now to make my own acurate bar from next size up .
                    MW
                    #82268
                    jason udall
                      @jasonudall57142
                      btw how out of round…guess enough to foul
                      We used to use “gauges” with tenth micron resolution with centerless grinding looked round on them but wouldn’t turn between mic anvils.
                      #82269
                      jason udall
                        @jasonudall57142
                        .. [can not find way to delete duplicate post]
                        Edited By jason udall on 16/01/2012 22:33:24
                        #82280
                        John Haine
                          @johnhaine32865
                          Try typing rswww.com into your browser – much easier than using their catalogue
                          #82282
                          David Colwill
                            @davidcolwill19261
                            Is this condition described as obround?
                            Dave.
