Squareness gauge
Squareness gauge
Home Forums Workshop Tools and Tooling Squareness gauge
  • #522761
    Andy Shepherdson
      @andyshepherdson55441
      Work related so sorry. The object in the photo is called an Indi Square and we use it to check the squareness of a part relative to its mounting surface.
      I need another one and contacting tool suppliers they have both offered height gauge but i doubt it will be that accurate. We calibrate the Indi square to 2 tenths over it 12" travel. Any ideas anyone,
      Andy Shepherdson
        #522762
          < Drool >
          Have you considered using optical metrology ?
          https://www.taylor-hobson.com/-/media/ametektaylorhobson/files/product-downloads/electronic-levels-and-clinometers/alignment-systems_lowres_en.pdf?dmc=1&la=en
          Edit: https://store.gaging.com/indi-square
          Edited By Michael Gilligan on 26/01/2021 14:51:54
          #522767
          Brian H
            @brianh50089
            They're expensive aren't they? Mind you, everything's expensive to a model engineer.
            #522769
            MichaelR
              @michaelr
              Available in the United States Link looks a expensive tool.
              MichaelR
              #522770
              Tony Pratt 1
                @tonypratt1
                Posted by Andy Shepherdson on 26/01/2021 14:42:05:
                There is no doubt a height gauge will not be good enough you will have to pay serious $$ or use a cylindrical 'square' or similar.
                Tony
                #522773
                old mart
                  @oldmart
                  A quality height gauge would be straight enough, but will lack the fine adjustment for the squareness. I wonder if a base could be made incorporating the adjustment for a height gauge to mount on?
                  #522775
                  Tony Pratt 1
                    @tonypratt1
                    Posted by old mart on 26/01/2021 15:24:59:
                    I disagree, a height gauge is not designed or manufactured to use as a top quality squareness comparator, my opinion others will maybe differ. .0002" over 12" is going some.
                    Tony
                    #522779
                    old mart
                      @oldmart
                      Maybe not as you say, but it could be checked at the desired top and bottom heights and adjusted to be true at those points. Thats what that granite square is there in the picture for.
                      #522792
                      DC31k
                        @dc31k
                        Posted by old mart on 26/01/2021 15:44:10:
                        …it could be checked at the desired top and bottom heights and adjusted to be true at those points.
                        You are correct, providing that squareness is needed to be checked in only one place. On YT, both OxTools and Stefan Gotteswinter have shown versions that do this.
                        On the other hand, if you need to sweep from top to bottom checking squareness, then the height gauge may not be good enough.
                        https://ecatalog.mitutoyo.com/Square-Master-Series-311-SquarenessStraightness-Instrument-C1825.aspx
                        https://www.kunz-precision.ch/en/products/squareness/SQUARE-check
                        #522803
                        Andy Shepherdson
                          Posted by DC31k on 26/01/2021 16:17:31:
                          I have just sent an email to Kunz, looks just the job. Thanks
                          #522851
                          old mart
                            @oldmart
                            The Kunz Square Check 350 looks like a winner, but how much will it cost?
                            #522895
                            Tony Pratt 1
                              @tonypratt1
                              Posted by old mart on 26/01/2021 18:40:22:
                              I was thinking that & will they ship to the UK? it will be interesting to get the answer[s]
                              Tony
                              #522898
                              Andy Shepherdson
                                I’m thinking £2000 ish
                                #523063
                                Andy Shepherdson
                                  €3500 plus carriage and another €58 for a cardboard storage box. Ouch
                                  #523068
                                  Tony Pratt 1
                                    @tonypratt1
                                    Posted by Andy Shepherdson on 27/01/2021 15:46:59:
                                    You may get charged VAT etc etc, who knows?
                                    Tony
                                    #523077
                                    old mart
                                      @oldmart
                                      At that rate, paying the duty and VAT from the USA for another indi-square would be a consideral saving.
                                      #523095
                                      David George 1
                                        @davidgeorge1
                                        Here is the square checker I used and still have. They are bottle squares and the biggest at work was about 8 inch diameter and about 2 feet long. With a touch of engineer's blue they can check to within a few tenths if a thou. Here are my three diferent sizes I still have.
                                        David
