Colin – being very polite, but ordinary calipers are for marking out and comparing at ruler readings. They are not precsion instruments for repeatablity. They used to be all that was available, and people got very skilled at using them because they had to.
We have moved on. But, if you want to go that route, of course, your choice, but do you really want to get involved in some kind of battery connection or replaceable tips? Not on things that only cost a few quid in the first place.
You can very quickly with a pair of digital calipers feel when you are tight on a dimension, or slack, and you can set a dia or depth or insidide dia, and mark out to within .001″. (Personally I don’t like digital calipers, I’d far rather use a mike, but in terms of value per £ of measuring flexibility they are unsurpassed)
Calipers are grand, they have their uses – several in fact, but nowadays there are too many other ways of gauging more accurately and more repeatably to trouble with much investment of time.
If I might suggest it, clean the tips up on this set, and then buy the next set at a car boot sale for a quid. Rather than getting exotic about the tips, make something interesting like bits of a model or the like!
Again, for me, there is no sense in going back to Victorian engineering standards. We always forget that we are where we are now because they were forwards thinking and always sought improvement. There is IMO little sense in faffing about with calipers, then having to carefully fit scrape and file every component, when you can work to drawing and digital accuracy and make something that will work better, first time every time.
Edited By mgj on 25/03/2011 11:52:48
