“Speedy” frames
“Speedy” frames
Home › Forums › Beginners questions › “Speedy” frames
  • #91453
    Peter Simpson 2
      @petersimpson2
      Hi,
      Has anybody out there modified LBSC's 5" gauge Speedy using Don Young's modifications. I have the original drawings showing the dimensions of the frames. I also have a diagram showing the frames with the Don Young modifications. As far as I can tell the frame modifications look to be purely cosmetic as the location of the cylinders on both original and Don Young drawings are the same. Obviously there are significant changes in the valve gear as this is what the modifications are all about. As I have built the frames and running gear to the original drawings, I'm a little concerned with regards to pushing through with the Don Young mods if the frames require modification.
      #6165
      Peter Simpson 2
        @petersimpson2
        #91456
        DMB
          @dmb
          Hi Peter,
          I am fairly certain that an article was written by DY somewhere his mods, possibly in his own magazine, "Locomotives Large & Small". I think you need to track down this info b4 u go further. Sorry I cant be of any use as to where to find the info, but good luck.
          Rgds, John
