Smart and brown lathe
Home › Forums › Manual machine tools › Smart and brown lathe
Viewing 25 posts - 1 through 25 (of 28 total)
  • #404960
    Steve King 5
      @steveking5
      Good evening lads
      Relatively new to the forum and was just wondering if there's any smart and brown lathe owners on here.
      Thanks
      Steve
      #13494
      Steve King 5
        @steveking5
        #404966
        colin vercoe
          @colinvercoe57719
          obviously not!wink
          #404974
          Plasma
            @plasma
            Hi Steve.
            I have a smart and Brown model L capstan lathe.
            All original except for the motor.
            Still setting it up.
            Mick
            #404982
            John Gregson 1
              @johngregson1
              I have emco 8 lathe, can please help with the taper on the headstock as making a new backing plate for my 4 jaw chuck
              thanks john
              #404983
              Nealeb
                @nealeb
                I have a 1024 VSL, a bit scruffy but bought with lots of extra toys. Three-phase but now running from external inverter. After my Myford, the bed of this one looks like the deck of an aircraft carrier…
                #404985
                Brian Wood
                  @brianwood45127
                  I have the S & B Sabel, a nice and slightly upmarket version of the US Southbend lathe
                  #404987
                  Clive Foster
                    @clivefoster55965
                    Another 1024 VSL owner. Also slightly scruffy. Native metric and very accurate. Drives Direct 10 HP plug and play inverter powers everything in the workshop, one machine or one machine and the Hydrovane compressor at a time.
                    Being clutchless can be a bit irritating but simplicity of design is very attractive on an older machine. Stuff that isn't fitted can't wear out or go wrong. Expanding / contacting pulley pair gives mechanical varispeed drive and smooth flat belt to the spindle. Simples and effective.
                    One thing that really annoyed me was the general fuss and messing about needed to change from metric to imperial threading. Standard intermediate gear on the banjo is on a nice roller bearing stud. But as built you have to pull the banjo off and change the stud to a plain one for the compound conversion gear. Bolting the 127 gear to the standard roller bearing intermediate gear via a suitable spacer sorted that. Took about 3 DP and 3 fine BA threads off the list but I can live with that. Don't think I've ever seen a DP thread or any of the really fine BA ones.
                    #404991
                    Bob Stevenson
                      @bobstevenson13909
                      At Epping Forest Horology Club we have 5 model 'L' lathes in daily use with a cabinet of collets, chucks, step chucks, etc etc, and also a model 'A' later type, screwcutting lathe.
                      3 of the 'L's are as orignallly supplied to Hackney College circa 1971 and two others have been restored in house
                      Edited By Bob Stevenson on 14/04/2019 10:07:33
                      #405091
                      Steve King 5
                        @steveking5
                        Posted by Bob Stevenson on 14/04/2019 10:03:30:
                        Don't suppose you have a spare 48 toothed gear for the model A do you?
                        #405106
                        David Colwill
                          @davidcolwill19261
                          I have a 1024 smile p
                          #405133
                          Lathejack
                            @lathejack
                            I have a Smart and Brown Model A Toolroom lathe that I have had for over 18 years, it was originally suplied to the Atomic Energy Authority so it probably glows in the dark.
                            It's rock solid, built like a tank with large vee and flat guideways with a bed the width of a cricket pitch, well almost.
                            #405160
                            Hacksaw
                              @hacksaw
                              I've got a model M laugh
                              #405179
                              Martin Connelly
                                @martinconnelly55370
                                Join the two previous posts and you've got a model m that belonged to the Atomic Energy Authority.
                                Martin C
                                Edited By Martin Connelly on 15/04/2019 18:43:15
                                #405221
                                Lathejack
                                  @lathejack
                                  #405240
                                  Steve King 5
                                    @steveking5
                                    this is mine as i got it. It's running a 160v DC motor with speed controller.
                                    #405382
                                    Stueeee
                                      @stueeee
                                      I have had a Model A Mk2 for more than 40 years now. It had been in a REME workshop where they only worked on huge commercial vehicles. So my lathe had seen very little use when I bought it at a government auction. It has done plenty of work for me since.
                                      #405626
                                      Steve King 5
                                        @steveking5
                                        Posted by Steve King 5 on 16/04/2019 05:31:23:
                                        Could anybody tell me if my leg is a Mark 1 or a Mark 2 model a
                                        #405627
                                        Steve King 5
                                          @steveking5
                                          Lathe not leg
                                          #405631
                                          Clive Foster
                                            @clivefoster55965
                                            Steve
                                            Mark 2. The apron control layout is diagnostic. See **LINK** . MK 1 has a simple lever to select saddle or cross slide power feed not the knob and dial that yours has.
                                            #410497
                                            Rob Cook
                                              @robcook72351
                                              Posted by Rob Cook on 22/05/2019 20:18:47:
                                              First post. Seems a good place to start
                                              Picked up a very sorry looking model M Mk1 a few years ago.
                                              Started stripping it to sort the half nut engagement and kept going.
                                              Not finished yet but has been put back to work
                                              Picked up an L last year for the collets and chucks. Couldn't bare to break it so apart it comes. Paint job was misleading. Most of the machined surfaces had been treated to gloss white.
                                              Compound nut was bent like a banana but managed to aquire a new cross and compound to use for parts.
                                              Also have a capstan tailstock and lever cross slide for it I picked up from Bracehand.
                                              Getting closer to making swarf again.
                                              Edited By Rob Cook on 22/05/2019 22:32:13
                                              #410513
                                              Hopper
                                                @hopper
                                                Wow that's a solid machine. Look at that rear toolpost! Looks good in the new livery.
                                                #410537
                                                  Hi Rob,
                                                  See the website FAQs for advice on posting and linking images.
                                                  Rob Cook
                                                    @robcook72351
                                                    Posted by Neil Wyatt on 23/05/2019 09:14:41:
                                                    Hi Rob,
                                                    Thanks Neil, been spoilt using a zen for powered forum. Drag and drop and auto tagging images. Will read through later.
                                                    #411144
                                                    old mart
                                                      @oldmart
                                                      We have a model A mk1.5 at The Helicopter Museum, Weston Super Mare. Given to the museum when Westlands left the town.
                                                      It has a very worn bed, but still turns pretty true. We have carried out many modifications and repairs over the last few years.
