Really you should be choosing a silver solder to suit the job in hand, then choose a torch capable of doing the job and some.
While it would be nice to have a seivert, you can buy economy torch sets (with regulators and three burners) in several size ranges for the cost of the solder for a decent sized project.
For larger (but not huge jobs) you can also add background heat with a gas blowtorch, adding insulation helps.
On smallish steel parts I have done 'real' brazing (with brass rod and borax as a flux) when I have found myself without any silver solder. Where there's a will there's a way, but I wouldn't recommend this over using silver solder as its so much easier to get a decent joint.
As mentioned above, silverflo55 is a good general purpose choice.
