Posted by Wolfie on 18/10/2011 13:17:52:
As a matter of interest, why is stainless non-magnetic surely it has plenty of iron in it??
Hi Wolfie, to understand this fully, you would have to learn a bit of metallurgy. Below is a graph of carbon steels, the temperature on the left and the carbon content at the bottom. The graph shows the metallurgical state that cabon steels are in against temperature.
The next bit is a reply I made in the “Chronos Silver Steel, water or oil quench” thread.
Sam, I believe you are describing the allotropy of Iron.
I had to dig out my college notes from 1977 for this one.
Iron can exist in two forms, Ferrite and Austenite. On cooling, it is in its Austenite form at temperatures above the upper transformation line (695 to 920 degrees C)
As cooling continues through the transformation zone (between upper and lower lines) the Austenite changes to Ferrite. During this change Carbon is precipitated from the Austenite, because Carbon is insoluble in (Iron) Ferrite. The precipitated Carbon is in the form of Cementite which goes to form Pearlite, or in the case of steels with over 0.83% Carbon the excess cementite remains on the grain boundries.
Time is needed for these changes to take place. A slow cool will enable the changes to take place and will result in a large grain structure. A faster cool will result in a smaller grain structure.
However, if the cooling rate through the transition range is increased sufficently (i.e. quench) time will not be allowed for the changes from Austenite to Ferrite to take place. In this case there is insufficient time for the Carbon to be precipitated out of solution and this result in the Carbon atoms being forcibly locked in the Ferrite structure. This may be described as a super saturated solid solution of Carbon in Ferrite Iron.
Due to the distortion caused by the Carbon, the grains are acicular (needle like) and are very hard and brittle. The name of this structure is Martensite.
As I said earlyer, only Austenitic stainless steels are non magnetic, and this is because there is sufficient Nickel, Nickel and Chromeium or Manganese, to maintain the structure of Austenite.
Hope this helps.
Regards Nick.
