Kevin,
I understand where you are coming from for the location of the Z axis hand wheel. There are are couple of things you need to be aware of.
1. The Z axis hand wheel sits slightly below the base casting. So, if you are thinking of putting it on the bench as is, then the hand wheel will sit off the bench, unless you put riser blocks under the base of the machine.
2. The turning (moving around) of this particular hand wheel is mostly fine for people who don't have a disability or ailment. I have a form of rheumatoid arthritis which effects the strength and movement in my hands and arms at times. At times, this makes the turning of the hand wheel difficult, especially when moving the head up. Unlike the X3, the SX3 does not has gas struts to support the head. There is a great work around for this by introduction of two gas struts, which is discussed on another forum. If this is likely to be an issue for you, I would suggest that you see one of these machines in the flesh and try out this movement. In certain cases, addition of a bigger hand wheel also helps.
I had a similar problem when designing the SX2P. In that case, I had the Z axis wheel moved from the top to the top side, put in a different bewel gear ratio and put in a larger hand wheel. Result is the SX2P you see today which is a lot more user friendly for Z axis movement.
Regarding the points Paul raised:
It is well documented that the earlier models of SX3 had issues with the control board. We only started selling the SX3 after the torque issues were dealt with. We – ARC – consider the brushless motor control boards on the SX3 to be far better and stable then the brushed motor control boards. As far as we are concerned, they are far better than competitors offerings for brushless motor control boards of non-SIEG origin.
The SX3s we have sold to date do not suffer from low torque at low RPM. The torque is controlled from the control board, rather than the motor itself. Non-SIEG boards are still finding it difficult to address the torque issue, so they are solving the problem by introducing a high/low belt drive to such arrangement, but we believe that there are still consistency issues with such non-SIEG brushless motor boards.
Column twisting… Paul was probably doing something extremely heavy, as this comment is extremely rare, specific probably to a select few… for which I cannot comment. I could understanding the necessity for adjusting the gib on the head to reduce/remove the nod, but column twisting… generally No. I can confirm however that there was an article about another machine review in the MEW back in the day of David Clark where the reviewer of the non-SIEG machine made mention of this, but from a person who made such comments based on what he was told by the seller of the machine being reviewed, to which I fail to agree.
Powerfeed – the one which Paul had – was crap. We didn't sell it. The new one is supposed to be better, but we still wont sell it, until and unless we are happy with it. From our observations, the camp is split 70/30 in favour of the new powerfeed. So, if you decide to buy the SX3, you can either buy whatever is available from other sellers of SIEG machines, or make your own.
We are happy with the SX3, and this is probably the only machine in our range which we warrant for light industrial use – one step more than hobby use.
Whatever you decide to buy, good luck with your choice.
Ketan at ARC.
