Shop vac recommendations please
Home Forums General Questions Shop vac recommendations please
Viewing 25 posts - 1 through 25 (of 43 total)
  • #25334
    John Haine
      @johnhaine32865
      John Haine
        @johnhaine32865
        As my old and much abused Aldi shop vacuum cleaner has gone to the great tip in the sky, I need to get a new one. Any recommendations please for something that will suck up dust and swarf but won't cost too much? Or indeed, any "don't buys"!
        #304419
        mechman48
          @mechman48
          Cant help on that one John, I'm still using the same Vax wet & dry vacuum I've had for donkeys years, I just keep changing the bag when suction drops.
          George.
          #304426
          Ian Parkin
            @ianparkin39383
            Anything by numatic works for me
            henry,george,charles very good prices if you can find one secondhand
            #304429
            Brian Oldford
              @brianoldford70365
              Posted by Ian Parkin on 27/06/2017 08:36:54:
              Henry works for me. Came to me as a freebie with a defective switch. A few quid and a few days later a replacement arrived via e-bay. Job's a goodun'.
              #304430
              RichardN
                @richardn
                I have two of the Wickes wet and dry vacuum – about £40, but buy the 'wet' filter for it for about £8- you can wash it under a tap rather than the paper ones which have to be replaced. Sucks up swarf, dust, I also use one as an extractor for my cnc router – really effective, and one has lasted about 6-7 years, looks tired but still works as new.
                #304431
                ega
                  @ega
                  My Wickes Wet 'n' Dry has been excellent.
                  #304436
                  Ady1
                    @ady1
                    Still using a hoover aquamaster from 1994
                    They show up on a regular basis on a well known site
                    Edited By Ady1 on 27/06/2017 09:05:05
                    #304437
                    Anthony Knights
                      @anthonyknights16741
                      When my wife got a new Dyson, the old Vax wet and dry machine became available to use in the workshop. It has given excellent service over the past ten years, but I really must check the motor brushes.
                      #304438
                        My Wickes one was bought in 2002. I had to replace the on/off switch after storing rust remover in a cracked container on top of it and the end of the hose is worn down to a stub but it still works 100%
                        Chris Evans 6
                          @chrisevans6
                          Plus one for Numatic, I have a Henry in the workshop for over ten years and also one in the house. Avoid anything Dyson we have tried three or four over the years and all carp. Constantly requiring strip and clean or just falling apart.
                          #304445
                          William S
                            @williams
                            Our vacuum cleaner is an old Miele, sucks up anything we throw at it. The only down side is when something unwanted goes up it, we have to fish around in a swarf encrusted bag.
                            William
                            #304446
                            Vic
                              @vic
                              I bought a Nilfisk Aero from Screwfix when it was on special offer. It gets good ratings.
                              Jon Gibbs
                                @jongibbs59756
                                I have an old Earlex 1000W shop vac which I think is the same as the Wickes model.
                                Cheap and cheerful and I've been waiting for it to die for years but it keeps going strong.
                                The filter cartridge is worth buying.
                                HTH
                                Jon
                                #304455
                                mark smith 20
                                  @marksmith20
                                  Still using one called `the rowenta wet &dry cleaner ` must be from around 1980 as it belonged to my father in law before me. Reliable and easily emptied. Still has the original filter , though a bit worn.
                                  Just spotted a replacement drum filter for £8.99 so think i`ll get one , cheaper than some of the modern spares like Dyson.
                                  Like this one:
                                  Edited By mark smith 20 on 27/06/2017 10:15:56
                                  Edited By mark smith 20 on 27/06/2017 10:16:18
                                  Edited By mark smith 20 on 27/06/2017 10:20:14
                                  #304462
                                  ega
                                    @ega
                                    Posted by ega on 27/06/2017 08:51:55:
                                    PS
                                    In view of other posts about the Wickes branded product, I think my machine is the older type, possibly the same as Neil's, which uses a semipermanent cloth bag filter and replaceable paper outer bag. I prefer this type as the cartridges are expensive (interesting tip about using a washable filter but a lot of what goes into mine would not wash off).
                                    Mine came with a (?) waterproof cover over the switch which was such a nuisance that I discarded it. I'll try to remember not to store rust remover on top of it!
                                    #304464
                                    V8Eng
                                      @v8eng
                                      I use an Aldi wet / dry vac, stainless drum & great suction at a bargain price.
                                      This particular machine has been used for most of the crappy jobs in our household for quite few years + workshop duties.
                                      When it eventually packs up I really hope to replace it with another one of the same type.
                                      #304493
                                      richardandtracy
                                        @richardandtracy
                                        For a 'don't buy' – anything cordless. The battery usage profile will be killing for ni-cad's and lithium batteries will make it too expensive.
                                        Also my MIL gave us a 'Hoover' upright with a sintered plastic dust cup/filter which I used a couple of times in the workshop. Complete waste of time. Inadequate vacuum and the sintered plastic filter clogged with dust so fast it was unbelievable. Totally useless. But then, I think that was why she got rid of it in the first place. The fan may be useful for a blower for a forge, but I think that may be the best use for the whole thing.
                                        Richard.
                                        #304498
                                        John Haine
                                          @johnhaine32865
                                          Thanks for all the replies. I was really looking for a recommendation for something available new now as the old one is dead and the c*** piling up. I'd get another Aldi if it was the same and if I could wait for it to come round. Based on the online reviews I've ordered a Stanley from Screwfix. Will report back on whether it's OK!
                                          #304524
                                          MW
                                            @mw27036
                                            Henry henry henry..
                                            Michael W
                                            #304525
                                            Limpet
                                              @limpet
                                              Posted by Michael-w on 27/06/2017 15:20:58:
                                              Henry henry henry..
                                              Michael W
                                              Or Henrietta
                                              #304551
                                              JOHN KNIGHT
                                                @johnknight56112
                                                For many years I had an "Earlex" which worked well, when it dies I bought a " Karcher", which is awfull!. The main problem is that the Karcher has a pleated filter element which gets clogged very easily. The Earlex and similar models have a bag filter which the dust tends to fall of,f and therefore not clog.
                                                Frances IoM
                                                  @francesiom58905
                                                  my workshop vac a Goblin wet + dry I’m sure predates 1984(prob mid 1970s as it came with me from old house) and has been in use ever since – also have an aquamaster dating from early 80s – my impression of Dyson is that they must employ better marketing androids than engineers.
                                                  #304554
                                                  Antony Powell
                                                    @antonypowell28169
                                                    I vote earlex had two for many years, used for anything from brick dust to wood shavings and metal swarf, even pumped water and gunk out of the drains with them ……still going strong an still available.
                                                    Tony
                                                    #304559
                                                    alan-lloyd
                                                      @alan-lloyd
                                                      I vote Henry, no problems with these that's why builders use them.
