Hi Guys
Have same overspeed error E-05 when insert battery in Mitutoyo 293-601 digital micrometer. Tried preset held down through reset cycle and the when flashing p back releasing button and immediately giving the button a quick press. This was all done with mic jaws closed at 0 on barrell. But still reverts to E-05 after a very brief display of 0.000 mm that increments quicly with negative sign up to – 0.221.
So moved barrell well put to 10mm gsp between micrometer jas and repeared the hold preset down for more than 8 seconds until all 000.000 cycled and flashing p input seen and release of button flowing by a quuvk press gave s sustained 0.000mm with no E-05. Moved micrometer barrrl out and mic behaved as normal incrementing the display inline with the barrel rotation marks. So you would think all wells good after a preset at 10mm jar gAP but not really
The turning of the barrel back in so the micrometer jaws close worked to a point of 10mm jar gap then around negative -0.220 the display wentry to E'05 so a fresh hold had been reached.
Just want to know if othere mitutoto users have ecirencester the same snd if they fix it. Think this mic needs to have its contacts cleaned or reset which I believe is some sort of ring on the barrel with 3 initial screws no 21 followed by some inner no 16 setting of contact ring screws.
Any helpnot this piggy back post please
Ken
