Serious Sun-Glass
Serious Sun-Glass
Home Forums The Tea Room Serious Sun-Glass
  • This topic has 30 replies, 16 voices, and was last updated 12 May 2025 at 22:57 by Michael Gilligan.
Viewing 25 posts - 1 through 25 (of 31 total)
  • #797208
      Since moving to live at the North Wales Coast, I am having great difficulty with the bright light, and would appreciate any advice from the wise.
      When I had my cataract surgery several years ago, it was immediately obvious that more short-wavelength light gets into my eyes, and in bright conditions this is sufficient to cause overload.
      I am currently using fairly dark ‘wrap-around’ Sun-Glasses, but the problem persists.
      Serious recommendations would be greatly appreciated.
      … Is there an Aviator, or an Astronaut, in the house ?
      P.S. __ I have already asked at the Hospital, and their suggestion was ‘wear Sun-Glasses’
      bernard towers
        @bernardtowers37738
        you hit a problem Michael when you change the lens to be sufficient for you and when you turn round you cant see a thing, a bit like keeping a welding helmet on when you have finished welding. I feel for you as I have trouble when the sun is low.
        #797254
          Thanks for your empathy, Bernard
          Nicholas Farr
            @nicholasfarr14254
            Hi MichaelG, while I don’t suffer like you probably do, I’ve always had a bit of a problem with bright sunlight, most photos that were taken of me in my childhood, I’m squinting to try and stop it causing problems, sunglasses were quite expensive back then for my parents. I’ve always had to wear sunglasses during most types of sunlight every since I started driving, and the only tan I ever get, is a red one, which isn’t very nice at all, and was always getting told off by mum, when I took my hat off when playing outside in the sun. So I do sympathize for your problem. I do like sunny days though, although I have to keep myself covered up, or use loads of sunblock, which I really don’t like.
            Regards Nick.
            #797262
            Kiwi Bloke
              @kiwibloke62605
              Neither wise, aviator, nor astronaut, I fear, but here goes…
              I find sunglasses to be a mixed blessing. The sun, or sky brightness, gets into my eyes over the top, or around the sides of the ‘shades’, producing instant, temporary blindness. A wide-brimmed hat works wonders, and also protects the shiny pate! I suspect the sun is brighter here in NZ, even than on the Welsh coast, and I wish I could get darker lenses, but I believe that they aren’t available, because of ‘safety’ considerations…G15 lenses seemed OK, when in UK, but they aren’t dark enough (for me) for NZ.
              An auto-darkening welding helmet works pretty well, if you don’t mind the funny looks.
              Post cataract removal, can you sense ultraviolet as a distinct colour?
              #797263
                For the avoidance of unnecessary speculation 🙂
                This is the model I am currently using:
                https://www.ebay.co.uk/itm/396253341531
                … and I need to find something much more effective.
                  The brain does clever tricks, but that’s a very good question with a complicated answer:
                  Cataract surgery is done one eye at a time [typically weeks apart], and during that time it was very obvious to me that the colours in my two eyes were different … If I blinked rapidly between the two, the perception of a violet or yellow colour-cast was evident.
                  Once both eyes had been done, the brain simply does its magic.
                  Colour-constancy
                  Refhttps://en.wikipedia.org/wiki/Color_constancy
                  Paul Lousick
                    @paullousick59116
                    I live in Australia and we often wear sunglasses to protect our eyes from UV light.
                    £6.99 is about $15 and would only buy a cheap pair of glasses. I only use glasses with polarised lenses that block UV light and cost $40 +.
                    #797272
                    Kiwi Bloke
                      @kiwibloke62605
                      Michael, I now realise you were more concerned about excessive light transmission through the lenses, rather than being bothered by ‘leakage’ around the lenses. I’d still recommend a hat…
                      You might find something dark enough in Uvex’s range. A quick look shows that their ‘welding safety glasses’, e.g. ‘Pheos cx2’, which look entirely conventional, offer 2%, 14% and 46% transmission (and probably other amounts). Might work for you?
                      #797273
                        Price is not an issue, Paul … the prescription glasses that I have to correct the slight long-sightedness of the cataract replacement were over £400
                        [ these are weak-enough that I can drive with, or without, them … and are Zeiss photochromic ]
                        Macolm
                          @macolm
                          Mountaineering and skiing glasses are available down to one or two percent transmission. There are several makers, for example Cebe or Bolle. Prescription lenses are available in some designs, though I suspect from appointed opticians.
                          #797290
                          Weary
                            @weary
                            Michael,
                            I use Julbo Vermont Classic sunglasses.
                            I have had a cataract operation/replacement in one eye, combined with serious macular damage to both eyes, and climb at high altitude spending days on reflective surfaces under clear skies.  Whilst these particular sunglasses are not in any way ‘stylish’ they are extremely effective and have a ‘charm of their own’ and can be worn with panache!  The (adjustable) wrap-round side-arms mean that they do not slide off etc., once fitted.
                            Julbo have a wide range of sun-glasses covering a range of protection and can be found ‘reduced in price’ by shopping-around.  In my opinion/experience side-shades are essential.  Category 4 is the highest protection.
                            Their Millenium style looks like an update of, and more stylish, ‘Vermont’ and also features one version with a ‘reactive’ lens which would give you lighter protection under weaker sunshine whilst seemingly retaining the high protection under bright sunshine.
                            Phil
                            #797293
                              Many thanks for that, Phil … I will have a look this afternoon
                              This has become a serious problem with driving, and I need to get it sorted.
                                The plot thickens …
                                Posture
                                So it looks like I need Category 3
                                Metalhacker
                                  @metalhacker
                                  The ‘glare’ and sun intensity are different things. I too lived in Oz for years and always wore a hat, with a non reflective inside to the brim, that is important, which helped with the glare. You will also find that sun from the side or reflecting off the face side of the lenses affects things. In general the widest brimmed hat you can find is the best thing.My most recent one was a wide brimmed rain hat from M&S which coped with the sun in Japan very well. The main thing is experiment till you find what suits you, and don’t look in the mirror when you have found the best solution!
                                  #797361
                                  Nick Hughes
                                    @nickhughes97026
                                    I use and would recommend these:-
                                    https://www.vallon.com/en-gb/products/heron-ocean?variant=34550727770279
                                    as they work well for me.
                                    I also have a pair of the Julbo Vermont and again they are excellent, but a bit too dark really for general day to day use.
                                    Use both on my motorcycle and the side shields with nose protector, keep wind and side/back reflections out of my eyes.
                                    #797364
                                    Tony Pratt 1
                                      @tonypratt1
                                      Michael G, I would not be buying serious eye wear from eBay, too much crap/fakes/copies on there to trust my sight too.
                                      Tony
                                      #797371
                                      duncan webster 1
                                        @duncanwebster1
                                        Wearing dark sunglasses whilst driving is OK until you go into a tunnel, then you can’t see a thing. Flipup clip ons have the advantage that they can be flipped up very quickly leaving the normal correction glasses still on your face. No side shields of course.
                                        #797375
                                        Speedy Builder5
                                          @speedybuilder5
                                          #797380
                                          Grizzly bear
                                            @grizzlybear
                                            Hi Michael,
                                            Go to a decent optician.
                                            Good luck……….
                                            #797392
                                              Tony
                                              That  ebay listing was just for convenient reference to the ones that aren’t good enough.
                                                On Grizzly bear Said:
                                                Hi Michael,
                                                Good luck……….
                                                As serendipity would have it … My excellent Optician has just eMailed with an appointment-reminder, so that’s a 120 mile round trip for me on Wednesday morning.
                                                Please all pray for overcast weather !
                                                peak4
                                                  @peak4
                                                  One thing to take into account, if you are considering polarising sunglasses, is what sort of camera you use.
                                                  They are not compatible with some electronic viewfinders, though fine with others, so maybe take your camera(s) with you.
                                                  Bill
                                                  #797511
                                                    Don’t know it it’s still done this way but fast-jets solved this with a two part solution.   The windscreen is polarised and so is the pilot’s visor.   The visor could be rotated by the pilot providing almost instant control of the external light level, without darkening the inside, so he could always see the instruments.  Much better than sunglasses.   Hate to think what it cost!
                                                    I wonder if a two part system would help Michael.  An ordinary pair of sunglasses fitted with the a flip-up clip-on of the type sold to us cheapskates who can’t afford prescription sunglasses!   When the ordinary pair are still to bright, flip down…
                                                    bernard towers
                                                      @bernardtowers37738
                                                      My prescription sunglasses have the annoying feature of making part of my car dash display disappear or darken some of it so its unreadable.
