Seeking someone to make a component (spacer)
Home Forums General Questions Seeking someone to make a component (spacer)
Viewing 19 posts - 26 through 44 (of 44 total)
  • #188909
      > Make items from Nylon and then boil them and they will not absorb moisture or swell!
      That's like leaving your nails in seawater for a month, so they don't rust…
      Oompa Lumpa
        @oompalumpa34302
        Posted by paul 1950 on 06/05/2015 18:32:47:
        well make them for him or shut up, simpleswink
        I offered to do that at 10.30 this morning but the OP hasn't worked out that there is a messaging system on this forum because, despite being logged in, he has not yet read it.
        06/05/2015 10:32:10 Richard Rogalewski offline spacers Unread
        Next comment please……
        graham.
        Edited By Oompa Lumpa on 06/05/2015 20:38:23
        Edited By Oompa Lumpa on 06/05/2015 20:39:18
        #188953
        Richard Rogalewski
          @richardrogalewski21509
          Oh, just now seen my inbox. Forgot about that. Will action after I've voted.
          #188956
          Richard Rogalewski
            One point. These spacers are normally porcelain. I assumed that a product I can buy (but not suitable – shape wise) was nylon. But it's probably porcelain or ceramic. I suppose I'm okay with nylon. I know there is a meter board specification. Don't know if there is a spacer specification for meter boards. Quite obscure specification.
            Certainly, I belive the spacers were meant to prevent damp affecting the meter board.
            Edited By Richard Rogalewski on 07/05/2015 10:10:22
            Edited By Richard Rogalewski on 07/05/2015 10:12:25
            #188961
            Jon Gibbs
              @jongibbs59756
              This document lists PVC spacers as being required…
              From these folks…
              Wootons & Co Ltd, Unit 3, Grove Industrial Park, Grove Lane, Padiham, Burnley, Lancs, BB12 8DN
              Tel: 01282 777315
              Jon
              #188973
              Russ B
                @russb
                Posted by Oompa Lumpa on 06/05/2015 17:22:02:
                Posted by paul 1950 on 06/05/2015 13:10:52:
                "Nylon absorbing moisture" – Really? It is that Mission Critical we are even going to consider this? Give me a break. It isn't worth considering and if we are going to consider electrocution, again, really? We have an earth I take it?
                graham.
                Edited By Oompa Lumpa on 06/05/2015 17:22:42
                Thanks Graham – I read the original request, saw porcelain and electric and thought automatically it must be insulating for some reason, perhaps high voltage.
                I also use Direct Plastics and would recommend them, and off topic, I've bookmarked these **LINK** for a potential order of some 3 to 5 mm steel plate for a project.
                #188985
                Brian Rice 1
                  @brianrice1
                  Here's the deal £10 each that takes into account the cost of my time plus cost of machines and tooling ,why have a workshop just get someone to do the work for you. A few plastic or fibre washers will do this little job .
                  #189006
                  Richard Rogalewski
                    I should have stated PVC then, rather than nylon. Don't know why I assumed nylon. Actually, practically, the main requirement is that the spacer looks a bit like porcelain in appearance. Trying to get a sort of visual match with the meter board spacers.
                    Just going to see what PVC round bar is on sale.  To get an understanding of what's available.
                    Edited By Richard Rogalewski on 07/05/2015 17:42:45
                    #189007
                    Vic
                      @vic
                      #189011
                      Ed Duffner
                        @edduffner79357
                        Didn't one of the Sieg lathes offered by Arc have a larger than standard bore?
                        Ed.
                        #189013
                          If you want it to look like porc then maybe white corian would be a better bet, polishes up to a reasonable shine.
                          #189017
                          Richard Rogalewski
                            Just to keep people informed: I contacted the first chap who offered to make the spacers. I'll probably end up sending him the required round bar. Corian as a material – noted.
                            #189019
                            Lambton
                              @lambton
                              "That's like leaving your nails in seawater for a month, so they don't rust.2
                              Another silly analogy .. Ffor moulded nylon parts to reach their optimum physical properties they need to be immersed on water – often boiling water to "normalise" them. This is standard practice in the plastic moulding industry See **LINK**
                              #189039
                              Vic
                                @vic
                                If PVC is the reccomended stuff use that, it's cheap enough.
                                #189050
                                Bunny Crabb
                                  @bunnycrabb20762
                                  I would pass on the same suggestion that was made to me. It was to contact someone with a 3-D printer that could print your spacers so they look original and even use an off white so they look aged, or buy one to use. I bought one new for $265 US dollars, as it was cheaper to buy than make for me with the price of my time spent.I have been printing items on a daily basis. I added a 3-D scanner to it mold or carve the part the duplicate it as many times as needed. I am currently booked up for the next 19 weeks. I would offer my services to you, if you couldn't solve it yourself, but I am overloaded machining and casting or printing parts. It is a money maker and If you want plans I have some for a 3d printer. working in this craft, it would be simple to accomplish.
                                  #189092
                                  john carruthers
                                    @johncarruthers46255
                                    That's what I like;
                                    wake up in the morning, and before I've finished my first coffee I've learned something new 😀
                                    (nylon)
                                    Edited By john carruthers on 08/05/2015 16:25:56
                                    #189097
                                    Vic
                                      @vic
                                      I looked at the spec for various different plastics for a particular project years ago and found that most of them absorb water to some degree.
                                      Needing slippy stuff I went with Ertalyte TX in the end. wink
                                      #189102
                                      paul 1950
                                        @paul1950
                                        save me lighting up my forge anyone want to make me a bench hold fast, i will give you a couple quid! wink
                                        #189189
                                        Brian Wood
                                          @brianwood45127
                                          All this talk of water absorbtion is really just plain nonsense, my board is timber sheet, possibly plywood, mounted flat on the external wall and screwed to it with wood screws through porcelain collars under the screw heads, looking very much like those drawn by the OP.
                                          There is no apparent protection at all such as a moisture barrier to the timber sheet, the collars are there purely as insulators to isolate the board from the screws. Clearly a damp board, which mine isn't, doesn't matter at all !!
