Locktite 574. Specifically designed as a high temp flange sealant. Its not really a locking compound, – its a thread and flange sealant. and is reasonably easy to undo, but still has antivibration qualiites. (592 I don't know sorry, but being a 5 they are possibly in the same series so could well be very similar)
Sets in a couple of minutes, easy to wipe off don't use too much. Seals everything, replaces all gaskets! Perfect – tool for the job. (I have an absolutely leak free traction engine, and an equally leak free Metre Maid, and no extraneous bits of white to get in the boiler and block injectors etc later!).
About £15 for enough to build and keep 2 engines running for 2 years and more! Available from Polly amongst others.
Why should one not use Loctite on a safety valve plug? You need a spanner to undo it just the same? With respect , there are very many Loctites, and while we normally talk of it as being a thread locker, they make, as we know high temp steam sealants, all the way to low strength nutlockers.
Edited By mgj on 20/06/2012 09:00:37
