There is a thread here:
https://www.model-engineer.co.uk/forums/postings.asp?th=133708
where, in the fourth post, a link is given to a very comprehensive data pack for the Bantam.
I am using page 16 (6 of 15 in the pdf) from that as a reference.
It gives a formula for threads not available from the gearbox: DRIVER/DRIVEN = (7 * Z )/(3 x Y * TPI)
Y is 1, 2 or 4. Z is 12 through 7.
If we pick Y = 1, Z = 9 and TPI = 27, the formula reduces to DRIVER/DRIVEN = 7/9.
There are only 18 possibilities with the formula so you can work through all of them to see if a better one emerges but I think the 7/9 above is the simplest.
Now the only gear you have with 9 in it is 36 (9 x 4), so the driver would need to be 7 x 4 = 28, which you do not have. 21/27 gives the correct ratio, but no 27t gear. 35/45 is correct, but no 45t. 42/54 is correct but no 54t. 49/63 is correct, but no 63t.
Any one of the missing gears above would solve the problem, so it gives you a few options if buying or making an additional one is a possibility.
