Hi Woolfie
Do you have an old cutter, a decent size?
If so, procede as follows.
Grind away 3 of the teeth.
Carefully sharpen the 4th tooth on the hand grinder.
Then put a small chamfer on the tooth, say 20 thou at about 45 degrees.
Carefully run all over the block with the cutter. That should give a good finish.
Basically, you would be using the cutter as a small flycutter.
Ideally, to get a good finish, a flycutter would be best.
Looking at the material, I think it is a crap bit of material. I used to get finishes like that on rough stuff.
Right, finish milling. When taking a fine cut, a couple of thou for finishing, I would go about 3/4 the width of the cutter and use the cutter so it is cutting into the edge (climb milling).
Then run back down the far side doing the same.
Then clean up the middle.
That way, you are pushing the material onto the work and there will be minimum burr.
Do it the normal way and the burr is thrown over the edge.
Climb milling is ok when you are only a thou or two deep and you nip the table lock up very lightly.
regards David
