Hi all .
Thanks for the replies .
Michael G .
I will have a look at or for some tufnol sheet and check the specs for suitability but this sounds good .
Martin : as from what i have seen with air tools and rotary vane vacuum pumps that i use at work the main difference is the positioning of the exhaust and inlet ports.
For an air tool it is usually at 12o'clock and 6 o'clock from the inlet to exhaust or there abouts and for a vac pump which will also blow pressure the inlet would be at 10 o'clock and the exhaust at 2 o'clock or there abouts .
I plan to plug the exhaust holes that are drilled in the housing and machine a new set at aprrox 3'oclock and re- machine all internal surfaces .
Michael W.
There is no chrome plating on this unit and it was also used to try and stop the chatter effect that vane pumps develop – this was from over reving the pump which caused the vanes to bounce or from sticky vanes – i wish the hardchrome company i worked at 25yrs ago was still going as i could have got mates rates on a chrome bore !
The pump will mount directly to a new 50cc two stroke engine i picked up on E-bay for $75au inc clutch unit .
The bearings will be sealed units and ther will be no oil feed as i don't want oil in my tyres !
The pump will be reving at around 6000rpm for i hope less than 2 -3 min per tyre then back to idle .
There is no metal to metal contact and the only wearing parts are the vanes in which i can make a few sets for spares .
I wish i could go back ten yrs in time as my workplace threw out boxes of spare vanes for vacuum pumps in a workshop clean up
I always wonderd what they were made of though .
Ian
