rivet squeezer castings
Home Forums Workshop Tools and Tooling rivet squeezer castings
  • #479063
    Suffolk Brian
      @suffolkbrian
      anyone know if anyone still makes/supplies "castings" for rivet closing tools? TIA.
      Suffolk Brian
        @suffolkbrian
        a riveting topic…..
        #479086
        Bo’sun
          @bosun58570
          Hi,
          Not quite sure what you mean by "castings for rivet closing tools" specifically, but Chronos sell Snap Head rivet setting and forming tools. Are they the same thing? I've just bought a pair for 1/16" Snap Head rivets.
          #479088
          Bazyle
            @bazyle
            Do you mean a toggle action rivet tool, a watchmaker's bush and riveting tool, or air riveter or a rivet snap?
            I think Tracy Tools used to do snaps but probably most people just make one.
            #479093
              Atelier do them, you may also want to enquire with Polly Eng who sell assembled ones as they may also do the castings.
              EDIT, Polly do list the castings, page 39
              Edited By JasonB on 11/06/2020 13:00:44
              #479168
              Suffolk Brian
                @suffolkbrian
                Grateful thanks, Jason B. The Atelier ones look perfect – but I shall have to enquire if they ship to the UK. Otherwise, it will have to be the "Polly" one. I remember some years ago someone did a kit – not Hemingway – and the actual casting was made from a hardened steel. Might have been Bruce or Maidstone.
                Thanks everyone.
                #479173
                  Polly and Bruce are one and the same. I'm not sure if they are cast steel or ductile iron.
                  I've altered the title in the hope Roderick Jenkins (Rod) will see your post as he has made the set of 3, if not you could PM him
                  #479178
                  Roderick Jenkins
                    @roderickjenkins93242
                    I bought my castings direct from Atelier. The castings are very nice quality iron. However, I have not found that the resulting tool is very satisfactory, there seems to be too much flex in the castings for copper rivets. I was warned off after I'd ordered mine and my correspondent recommended adapting a pair of compund action pliers instead.
                    HTH,
                    Rod
                    Edit: I think these are the pliers that were actuall recommended https://www.fabory.com/en_GB/knip-plier-wr-86-8603-150mm/p/K1086300150?gclid=Cj0KCQjwrIf3BRD1ARIsAMuugNurT6kMG3O1FALXNlh9Mj76MqLCkIGpfCoshm6JgEEKGSVutR1TJ04aAlSAEALw_wcB
                    Edited By Roderick Jenkins on 11/06/2020 19:47:50
