Repairing stripped thread in Walker Turner bandsaw
Home Forums Manual machine tools Repairing stripped thread in Walker Turner bandsaw
  • #14150
    AJAX
      @ajax
      AJAX
        @ajax
        I have an old Walker Turner bandsaw that I'm finally getting around to repairing. I have all the parts but there's one thing I would like to fix before reassembly. The top wheel has an adjuster for tracking and it appears that someone stripped the thread and/or used an M8 screw. I don't trust the thread enough and don't want it to give way during use. Failure might lead to the top wheel making sudden manoeuvres.
        Here is a closeup of the tapped hole. As you can see, there's not a lot of material to work with. It is diecast something (pot metal?) that goes with the era. The rest of the machine is very solid cast iron.
        h2 h1
        I have been tempted to mill this part down and make a replacement "lug". However, there's really not a lot to screw this lug into. If I have to do more complex machining I'd be tempted to make a new assembly of my own design but I'd rather a small job didn't grow into a big one.
        If you want to know what it could look like, here is an example (not my own)
        Thanks,
        #522897
        AJAX
          @ajax
          Something else I forgot to add:
          Would filling the hole with JB weld, drilling and tapping be a viable solution? I'd much rather fill it with metal.
          #522899
          not done it yet
            @notdoneityet
            Helicoil?
            #522901
            Phil super7
              @philsuper7
              Repair the thread with a helicoil
              #522925
              AJAX
                @ajax
                Thanks for the helicoil recommendations. I've never used one before but I knew they exist.
                Measuring the internal diameter of the threaded hole (the "minor diameter&quot indicates about 7.64 mm. There's probably less than 1.5mm material to one side. I'm assuming the original screw was 5/16 BSW.
                I just watched a YouTube video to get an idea about how a helicoil could be used. He drilled and tapped the hole, then installed the helicoil. No shortage of taps here but I'm not keen on enlarging the hole.
                Are helicoils suitable for a through-hole? The screw must pass through the threaded section.
                Any suggestions?
                #522928
                Neil A
                  @neila
                  To be honest the remaining wall thickness after using an M8 x1,25 helicoil tap looks as though it will be rather thin from your photo. From the helicoil information it should be a minimum of 3,5mm but may not be enough if your assessment of the metal is correct.
                  Is there any mileage in machining out the existing poor thread and fitting a headed steel bush which has a plain 8mm diameter section, that is Loctited into the hole, and an M8 x 1,25 threaded end for a nut and washer?
                  Perhaps you could just fit a through bolt and Loctite that in position, I don't know how much room you have.
                  There does not look to be much metal to play with, it might require a bit more thought.
                  I hope it works out.
                  Forgot to say, the outside diameter of an M8 x1,25 Helicoil tap is 9,6mm, tapping drill size 8,4mm.
                  Edited By Neil A on 26/01/2021 22:40:33
                  #522935
                  AJAX
                    @ajax
                    Posted by Neil A on 26/01/2021 22:23:06:
                    Thanks, Neil.
                    I've had a few more thoughts about a possible solution. If re-tapping / threading the hole is a problem then I could take an entirely different approach and turn a plug that fits in the centre hole (see photo below) and cross-drill and thread that plug. It's not quite as simple as it sounds, as the centre hole is used for the height adjustment, but that shouldn't be too difficult to modify either.
                    h3
                    I will probably be back…
                    #522936
                    bernard towers
                      @bernardtowers37738
                      Through hole helicoil inserts are different to the blind hole version, they have a center coil that is kinked outwards to hold it in position. I have used them with great success. Have a word with the man at Tracy tools who specialises in inserts.
                      #522939
                      peak4
                        @peak4
                        Could you fill the hole completely, with one of the low melting point aluminium solder/welding rods, and the jut re-drill and tap.
                        Maybe one side smaller to as not to impinge on the thread/solder interface.
                        Bill
                        #522942
                        Jeff Dayman
                          @jeffdayman43397
                          My suggestion would be not to waste your time with old pot metal (which was just barely up the job at the start due to the small wall thickness at the boss, and may have been cracking internally since). You will just end up with disappointment when it breaks somewhere else, maybe splitting when tapping for helicoil, or strips again if JB weld is used. The geometry looks simple enough that the part could be remade as a steel fab of a central machined block and separate arms welded or silver soldered on the sides. Or if you have machine capacity you could carve it out of one block of 6061 or 7075 aluminum. Either way you will not likely ever have an issue with it again. Do it right and do it once. Just food for thought.
                          #522945
                          AJAX
                            @ajax
                            Posted by AJAX on 26/01/2021 22:43:18:
                            h3
                            As promised, I'm now back after having another look at the tilt and height adjustment.
                            The easiest, cheapest and strongest solution will be as mentioned above. I will turn a cross-drilled and tapped shaft to fit in the centre hole. The tilt adjust screw can then go through the existing dodgy thread before passing through the newly tapped shaft.
                            The hole is bored to accommodate the height adjustment screw and a spring (adds tension to the bandsaw blade), but springs can be easily added to the rods either side and then all I need to add is a small bush. I tried a couple of valve springs from my junk box and it worked fine, but stiffer springs would probably be even better.
                            It's actually much easier than I had thought.
                            I'll try to get it done one evening later this week.
                            #522952
                            Neil A
                              @neila
                              That looks to be a good solution to your problem.
                              I can now see that my idea was a non-starter, I had not understood how the screw functioned.
                              Howard Lewis
                                @howardlewis46836
                                Possibly being pedantic, and sticking to prototype, what was the original thread? Possibly not Metric but Imperial or Unified? In which case it might be 5/16 rather than M8
                                If BSF or UNF would give a finer adjustment ( 22 or 24 tpi ) rather than 1.25 mm which is nearer 20 tpi.
                                #523180
                                AJAX
                                  @ajax
                                  Posted by Howard Lewis on 27/01/2021 11:45:09:
                                  5/16" was my original assumption and subsequently confirmed by measurement. I believe these Walker Turner bandsaws were made in the USA in the 1930s / 40s and that must have an influence on the threads we can expect to see.
                                  Thanks for your contribution
                                  #523181
                                  AJAX
                                    @ajax
                                    As mentioned earlier, I decided to go for the simple and secure option with a turned "shaft" mounted in the central hole and then cross drilled and tapped. I won't bore you with the details as it was an easy job requiring just a couple of new parts and the height adjust screw being shortened. I used brass for a bush and aluminium (type unknown) for the shaft as that's what I had in the junk box. The tilt adjust mechanism now feels rock solid and I have confidence it cannot easily fail.
                                    20210127-200714
                                    #523310
                                    Howard Lewis
                                      @howardlewis46836
                                      Thanks for telling bus the outcome.
                                      Glad that you have it working to your satisfaction.
