Reilang oilers
Reilang oilers
Home › Forums › General Questions › Reilang oilers
  • #24957
    steamdave
      @steamdave
      #273401
      steamdave
        @steamdave
        I have two Reilang oilers; one works and one doesn't and I can't find out why the one doesn't.
        They are very simple bits of kit – two telescopic brass tubes with a compression spring in them and a ball valve on the outboard end.
        The ball is free to come off its seat, I don't see any damage to the seat, nothing else amiss that I can see but it just won't pump.
        Anybody got any ideas what to look for/at? Is there another ball at the base of the spout that I haven't noticed?
        #273417
        V8Eng
          @v8eng
          Not had mine for long, I did find a video on the subject of dismantling them while investigating before buying one.
          There is a ball and spring at the spout base.
          Edited By V8Eng on 23/12/2016 14:18:20
          #273517
          steamdave
            @steamdave
            Well, I watched the video. The design of the oilers has certainly changed since mine were made but the basic idea is still the same.
            I stripped mine down once again, poked around a bit and reassembled it. It now works, but which bit of poking did the trick, I know not.
            The Emerald Isle
            #273527
            Nick Hulme
              @nickhulme30114
              All it takes is a small particle of dirt stuck on the valve surface and they don't work, simply stripping & rebuilding often dislodges something on the valve face causing failure to generate the required pressure to flow oil,
              – Nick
