Recognising tooling quality levels?
Home Forums General Questions Recognising tooling quality levels?
Viewing 14 posts - 51 through 64 (of 64 total)
  • #194779
    Mike Poole
      @mikepoole82104
      I suspect that to turn to fractions of a thou it will be necessary to master sharpening and setting the tool to a high standard, if using insert tooling the selection of tip and setting will still be important. The performance of a machine can be maximised in the hands of a skilled user. The old saying "a bad workman blames his tools" can often be true. A lathe of the highest quality may not deliver work of the highest standard unless the operator masters the setup of the machine and the material being turned. We all need to understand the limitations of the machine aswell as the limitations of the operator to get the best of our equipment.
      Ian Maybury
        @ianmaybury77488
        smiley It seems like i may unknowingly and unintentionally have sailed close to re-igniting a few smouldering brush fires Neil. My apologies.
        To be fair i'm not looking for ultimate precision at all – at least not in any general sense. Nor am i looking for production type longevity. I am though looking to get into a position to identify stuff that will do a straightforward machining job to reasonable general jobbing shop levels of accuracy for a reasonable period of time – bearing in mind the equipment i'm running.
        The market is the problem – it's a mess. If it was possible to buy stuff and rely that it did what it said on the tin/was implied by sellers then most of the issues would disappear.
        Hard experience suggests that once it's in your shop that no matter what the paperwork you're stuck with it – with minimal comeback unless you have the time and money to hand to play hardball. So getting it right up front is the only realistic option.
        contd – it think too many words
        Edited By Ian Maybury on 24/06/2015 22:02:54
        #194784
        Ian Maybury
          @ianmaybury77488
          contd
          The trouble is that I haven't got five years or the budget to spend finding out the hard way what works, and what doesn't – to become a pundit/holder of the sacred mysteries. I have a budget, need to set up the mill and then get on with my woodworking.
          The Chinese by taking us at our word/actions have thoroughly messed up the old status quo. They don't at the lower end play the Western game where the customer gets to press indefinitely for ever cheaper stuff, but the makers remains on the hook to deliver decent quality.
          They by all acounts will make a 5p tool if that's what you want, or equally happily a £50 tool. The re-seller will likely claim both to be xyz – or will at least not explicitly state the differences.
          It's very educational in one way, in that they seem to simply reflect back to us what we claim to want. The old saying that 'the worst thing that can happen to a person is that their greatest wish comes true' comes to mind.
          To again pitch it at a very basic level. The problem is how to identify tooling at or above the above general jobbing machine shop level. I've for example no problem running with HSS tooling on much of the time, understand the need for correct geometries, surface finishes and cutting speeds if good finishes/decent tolerances are to be achieved – and will happily reduce speeds and cuts accordingly.
          What i can't for example deal with though is (as happens frequently in woodworking at the mainstream market level) buying say a tool billed as xyz, only to find that it's actually made of bubblegum masquerading as xyz so that the tip wipes off in minutes. Or whatever.
          The magazines etc in woodworking (engineering is presumably similar) are a dead loss as a means to judge the differences. Forums generally are not a whole lot better.
          What seems to be coming through here (?) is that it's inadvisable to buy stuff in the lower priced end of the ranges of the sellers mentioned – but that going to the higher priced stuff in their ranges generally buys stuff that will function very decently at the general machine shop level described.
          I hope….
          Thanks again.
          ian
          Edited By Ian Maybury on 24/06/2015 22:05:02
          #194787
          Ketan Swali
            @ketanswali79440
            Ian,
            You believe what you wish to believe. That is your prerogative.
            In my opinion, I feel that you are simply wrong in your understating of the metalworking commercial or hobby market. Metalworking hobby market is not in a mess. It is just your thinking that it is because you are unable to get clear answers, which needs to be taken into consideration.
            If you are talking woodworking, this is the wrong forum for you to get the answers you seek.
            If you are seeking answers to metalworking issues, perhaps you would do better by considering a positive approach rather than continuously bad mouthing sellers and product origin. I get that you don't want cheap Chinese. That is fine. Why keep going on about it? You have been given options for alternatives, so best get on with those.
            This is of course my opinion, in the same way as you are entitled to yours.
            Ketan at ARC.
            #194795
            Ian Maybury
              @ianmaybury77488
              I'm sorry Ketan, but i'm pushing no belief whatsoever – but i do for reasons i'm unaware of seem to be inadvertently ruffling your feathers. I have absolutely no axe to grind with you or your business.
              I've gone to considerable trouble to try to honestly describe what based on my experience to date seems may be the possible situation in the market.
              I'm more than happy to use Chinese product, and the cheaper the better provided it does the job it's bought for – i've just proved it by buying the mill drill.
              I've also however been down the road several times of buying Eastern made stuff that in very simple terms was junk – despite it's billing.
              I also run some Chinese stuff which while it's definitely made down to a price and didn't conform to what had become the norm in terms of Western quality expectations hasn't been at all bad once de-bugged.
              I have had Japanese made stuff of exquisite quality too – which didn't cost an arm and a leg.
              You seem to be frantically resisting the possibility that there's possibly a continuum ranging from good (in the terms i'm trying to describe) and not so good in the ranges offered by yourselves, and by the other sellers listed.
              I've no problem with that (if in fact its the case), but as above am trying to establish some reference points to figure at what level i need to buy. I can for example buy ER chuck and collets in everything from DIN spec, tight runout hardened and ground from an industrial supplier, to stuff claiming tolerances and hardening but with no spec, to nondescript no spec, no tolerance and probably minimally if at all hardened material. The latter may be fine for what i want, but seems likely to be risky.
              If you're adamant that your entire product line is top quality/above the threshold i'm trying to describe then by all means – pitch the necessary undertakings and we'll go from there…
              Thank you again for the help guys, i think it's to a fair degree clarified my mind. Time for me to sign off.
              ian
              #194799
              Ajohnw
                @ajohnw51620
                I feel you are wrong to blame the Chinese for the problems Ian. True in some quarters they do have a reputation for providing excellent samples and even first production runs and junk there after but I don't think this applies to the sector that is under discussion providing things are bought from well known sources.
                I suspect the real problem goes like this. Some large scale importer wants to make the lathe bigger and better. Sorry I go on about lathes but they are classic examples. Say it has 18in between centres, adequate for many really but they ask for it to be increased to 20in. The supplier could make the bed 2 in longer at a cost. They could chop 2in of the tail stock. That is a much cheaper option, just saw 2in off the pattern or block off a mould. The importer is aiming to sell at a set price so which would you go for in the same position? I'm not talking small scale importers here I'm talking ones that buy in numbers that are significant to the supplier. Once it's done everybody else gets the same. Later the same people might want to get an even larger centre distance – the head gets thinner.
                I'm not going to rabbit on about more recent thinking on specification and marketing and problems as a result. It would come as shock to many people who expect to get what they have apparently paid for. Things haven't been that simple for a long time. And don't I know it, 39 years with the automotive industry. There is a chance as well that Chinese marketing people think the same way.
                It all leaves many retailers in an odd position. People want them so they sell them. My only feeling on that score is that certain sellers are clearly rather synical about it all. On the other hand it's understandable that in general they may not want to tell customers about any problems with a product.
                There can be other problems too. A couple of years ago one retailer was asking me why they had problems with a certain type of collet holder. They had done their best and had them produced by an aero space company and it didn't work out. Many complaints. This is different type of problem. Poorly conceived and based on a need rather than reality and in truth due to accuracy needs it's doubtful if any one could achieve even low production rates. Customers expect collet performance though – its' a collet holder and does hold collets. I find that hard to accept because to me the idea had it's advantages but clearly could have problems working as some one would expect collets to work. Maybe they are sorted now but some how I doubt it. This doesn't mean they are useless, just not as good as the real thing.
                Ian Maybury
                  @ianmaybury77488
                  What you say John makes perfect sense to me regarding what could be termed 'spec inflation'. The problem as you say is that engineering is a reality based and hard taskmaster. Stuff either is or isn't what it claims to be. If it's to be cheaper some smart design, materials or manufacturing improvement has to be made – or else the quality and performance will likely suffer.
                  I wasn't actually blaming the Chinese – more making the point that when we get what we (as customers or business managers) think we want it's not necessarily going to deliver a happy outcome.
                  The problem in keeping with the above is that if buyers keep on blindly pushing for lower prices, importers do the same but are less than forthcoming on product differences, and manufacturers adopt a ' wnatever you want boss' attitude – and none keeps the eye on the ball that is the little matter of quality and performance then only one outcome is possible.
                  This is the theoretical or risk scenario – i'm not trying to push a blanket view here. I'm in fact fervently hoping that a few knowledgeable souls will stand up and say that if you buy above xyz level from the likes of abc that reasonable quality is to be expected. (this seems to be what's coming through, but it's far from loud and clear)
                  It certainly makes sense there should be at least a few players in the market who know their tooling, are not just run by suits, and understand that retaining customers requires not p******g them off on their first purchase by delivering junk.
                  Against that i've been caught more than enough times in recent years, and seen enough businesses push sub standard stock into the market because they can't afford to wait for another delivery to readily accept bland assurances that noooooooo… that never happens here….
                  ian
                  #194818
                    Ian,
                    I have read this thread with interest, and; although your "Mission" is amirable, I don't think there is much hope of a definitive answer to the question.
                    The biggest problem [and this relates to your observation regarding the relentless push for lower prices] is that there are batch-to-batch differences between supposedly similar components. The "Manufacturers" [sic] subcontract most of the work, and the levels of supply-chain management are inadequate.
                    When I worked in the 'Aerospace' industry, we had full traceability [all the way back to the mine where the ore was found] … but this inevitably comes at a price.
                    The use of ISO9001 accredited supply chains should help you … but I fear that there is a lot of 'lip-service' being paid to the admirable principles of that system.
                    Please; If you do find a supplier of consistently good tooling, at affordable prices, tell the rest of us!
                    P.S. … One closing thought: Of the many 'Model Engineering' suppliers who could contribute to this forum, only ArcEuroTrade and CuP seem to do so with any enthusiasm.
                    #194826
                      Ian,
                      You are building a huge critical case against companies that you have not done business with and the entire thing is hypothetical.
                      You can't group companies into tolerance bands like you would reamers or bearings.
                      Experience shows that the vast majority of name suppliers to the metalworking hobby understand their business comes from repeat customers and that nothing is more valuable to them then a good reputation.
                      Read their product specs carefully and email them if you aren't sure. If their product doesn't perform to the promised standard, then I am sure they will refund or replace.
                      My worry, however, is that you are effectively setting a bear trap, with little thought of who might fall in it. Is it the retailer who sells you something over the net, whose spot-on cutter won't meet your requirements because your mill is not accurate enough, or the forum member who says XYZ are a good company but their product doesn't meet the standards you expect?
                      You need to relax and start enjoying your hobby and choosing and judging your purchases by the standard 'will it do what I need it to do'?
                      Martin Kyte
                        @martinkyte99762
                        XYZ are a good company.
                        Martin
                        #194841
                        Ajohnw
                          @ajohnw51620
                          One thing I wonder about lathes in the UK is where are the bench lathes like this one
                          There has been others even cheaper none geared head. It's interesting to read the reviews – they mention results. Never found any in the UK. The 0.002 – 0.003 between centres could easily be fixed and the machine may not have been installed correctly. I'd hope it had a hardened prismatic bed. Might turn out that it has 2 flat rails – nvg. Generally though it looks pretty sane and as I have said there has been others and probably still is.
                          Ian Maybury
                            @ianmaybury77488
                            Ta for the link Martin, but just in case – I clearly used the terms xyz and abc as a way of referring to hypothetical companies in general. Not to refer to any specific organisation.
                            Having little or no experience in it I have no view as to the situation regarding the levels of product offerings in the hobby metalworking tooling market. Hard experience in the related woodworking tools market suggests however that the well worn principle of 'buyer beware' may be as applicable there as anywhere else.
                            I'm at a loss Neil as to how to seeking some feedback guidance from private users on how to select suitable tooling to satisfy a given level of requirement on an enthusiast forum amounts to setting a bear trap – I thought that would be one of its basic functions.
                            As before I'm off – there seems little point in trying to push a rock up what for whatever reason is a very steep hill…
                            ian
                            #194853
                            Martin Kyte
                              @martinkyte99762
                              My link post was intended as a joke as I found it amusing how everything has multiple meanings. That's how Lawyers make their money.
                              Oh no I mentioned Lawyers, that's done it. !!!
                              :0)
                              Martin
                              #194961
                              Ian Maybury
                                @ianmaybury77488
                                Sorry guys – I meant to properly say thank you to those that contributed on this thread – it has actually been very helpful at the level of filling in a general view of the nature of the market.
                                It's a pity (clear as to why – but actually daft and i suspect highly negative for everybody in the field, especially for users and those taking care to offer well specified product) that it's apparently deemed not feasible to openly discuss product performance specifics on a user forum.
                                It's become clear however that there's a definite and to say the least impractically low threshold beyond which it's not seen as being wise to go. I'm at a loss as to why it should it be inappropriate for a private user of a particular tool or machine to describe his/her own experience. If it's negative but not typical then there's lots of experience elsewhere that suggests that there will be others ready to pile in to set the record straight. Either way one opinion is only that.
                                I should say that there can't be a problem with openly offering product at whatever level there is a market for – it doesn't all have to be high end/professional/industrial quality stuff.
                                There's a lot more that in the general sense that could be said, especially regarding the little matter of stakeholder and especially contributor input to moderator policies on the many user forums about these days. That however is for another day….
                                Thanks again guys.
                                ian
