I always run the machine under power when reaming.
In the lathe I run at a fairly slow speed, and with the “machine” reamer located in the tailstock barrel, I push the complete tailstock along the lathe bed and pull it back again when the reamer has got to depth.
In the milling machine or pillar drill, I just use the reamer like a drill but run it much slower.
In both cases I put a dab of the old fashioned neat soluable oil on the reamer, not because it cuts any better you understand, I just like the smell of it.
There will be plenty of differing opinions about this, but my dad taught to me to use a drill to remove the bulk of the material, then a single point boring tool to bring the hole to reaming diameter but round and true again, then finally the reamer to finish off to final size.
Also never stop rotating the work or the reamer until it has been fully withdrawn, and dont rotate it backwards.
I get the impression you were talking about using hand reamers though, so you might be better using the tailstock centre as opposed to holding them in a possibly inaccurate chuck.
Trouble is you need three hands to do it that way.
Phil
Edited By Phil P on 08/11/2011 22:41:16
